Ronin-SC Release Notes (09/26/2019)
11773 21 2019-9-26
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2019.09.26
  • Firmware: v1.2.0.10
  • DJI Ronin App iOS: v1.2.4
  • DJI Ronin App Android: v1.2.4
  • User Manual: v1.2
What’s New?
  • Added video recording, autofocus, and focus pull support for Sony A7R4 cameras with supported E-mount lenses using a Multi-Camera Control Cable (Type-C). To use autofocus on the A7R4, press halfway down on the camera control button of the gimbal.
  • Added photo capture, video recording, zoom, and focus pull support for Sony A7R4 cameras using a Multi-Camera Control Cable (Multi USB). To use autofocus on the A7R4, press halfway down on the camera control button of the gimbal.
  • Added photo capture, video recording, and autofocus for Fujifilm X-H1, X-T2, X-T3, X-T20, X-T30, X-E3 cameras using a Fujifilm camera control cable (RSS-F).
  • Added a quick switching function to Portrait mode. Press M button twice to enter/exit Portrait mode. Portrait mode requires using Ronin-SC in Flashlight mode and the joystick control is not available. Portrait mode can be disabled on the Ronin app Status page (requires Ronin app v1.2.4 or later). Note that the tilt axis will rotate 90° when switched to Portrait mode. Make sure the camera will not collide with the gimbal.
  • Added Force Mobile when using with the Android version of the Ronin app (requires Ronin app v1.2.4 or later).
  • Added disable 3D Roll 360 feature in the Ronin app (requires Ronin app v1.2.4 or later).
  • Fixed issue where the roll axis occasionally drifts after exiting sleep mode.
  • Optimized zoom adjustment when using a Sony camera’s multi-port with a power zoom lens. The zoom speed can be set from 1 to 100 (requires DJI Ronin v1.2.4 app or later).
Notes:
  • Update the firmware through the DJI Ronin app. Make sure that the DJI Ronin app is the latest version when updating the firmware.
  • If Ronin-SC has a camera attached and is turned on while updating the firmware, make sure to protect the camera and lens, as the motors will shut off during the update.
  • If the firmware update fails, restart Ronin-SC and retry.
2019-9-26
Montfrooij
Flight distance : 2845026 ft
Thanks for the info!
2019-9-26
fans9fd5113b
Flight distance : 13507 ft
Just updated.. thanks for the Fujifilm support!
2019-9-26
RLandor
I cannot update. The SC is not found by the DJI assistant software on Windows, and the mobile app cannot retrieve the firmware version...
2019-9-26
Curts Randall
Flight distance : 1272090 ft
DJI is on the ball! Constant updates like this really mean a lot to us. Thank you thank you
2019-9-26
GeorgeGreek
Flight distance : ****
Thank you for the information!!!!
2019-9-26
Bonninsky
When will the version be available DJI Ronin App iOS: v1.2.4 in AppStore Mexico?
2019-9-26
MK7GTI
@DJI Support
Thanks, but what about the Motionlapse that is available for iOS and missing at the Android app?
2019-9-26
Davist Wong
Thank God the roll axis drift is fixed, totally when crazy every time when to sleep mode and the roll axis slight drift away while shooting.
Anyways great job DJI
2019-9-27
Vathemankan
Thanks for the update DJI. I can confirmed that my Ronin SC now has Force Mobile working with Asus Zenfone 5 ZE620KL, G85 & Panasonic cable. Thank you once again.
2019-9-27
MavGuido
Flight distance : 338793 ft
Thank you DJI for the Force Mobile Android support, thats a uge step for me.
Overall thank you for the everytime updates! :-))
Thanks and regards
2019-9-27
Superbaso
So will we be able to do motionlapse with Fuji xt3?
2019-9-27
esteve
Flight distance : 104386 ft
Hello,
i have problems connectiing the roninsc with the mobile app. when i tried to connect the bluetooh the app reject the paring, and into the app only appears a promp with the password 12345678.
What can i do? i have a xiaomi MI 9 device.
Best regards
2019-9-27
JRos
Flight distance : 677362 ft
Thanks for the update....
But when focus pulling for Sony a6500 from focus wheel?
Thanks
2019-9-28
Rolfr
Flight distance : 20308 ft
Just updated to FW 1.2.0.10 and tried it with IOS and Android. Both apps are 1.2.4.
But only IOS works, not Android with the Force Mobile.
I use Huawei 10 Mate Pro.
@DJI Support is it something I can do?
2019-9-30
LAW SC XT3
Firmware up to date on XT-3 and Ronin SC as of today, still no record button functionality.
2019-10-5
fansfa24d265
Bought my Ronin SC today, updated to this firmware, followed YT videos on how to balance. Done everything right, hardware is balanced but the app says the Yaw is off.
When tilting 45 degrees the gimbal starts to vibrate heavily and the motor power goes to 100%
2019-10-5
fanse32c5b18
Thanks ! A lot ! Very nice functions !
2019-10-7
SLiWooDy
Flight distance : 126234 ft
Have you fixed the return to center issue after panning ?
2019-10-8
AnticipateMedia
Flight distance : 309626 ft
Is there anyway to update on OSX 10.15 Catalina? The installer does not work.
2019-10-15
Tom Lopez
United Arab Emirates
How about for us Canon Mirrorless users? I got EOS M6 and I can’t even use the start and stop recording of Ronin SC. Please support my old camera. TiA
2019-10-25
djiuser_e4QhaHuavgPp
Flight distance : 23944 ft
Panama
Saludos tengo un problema al conectar la canon m 50 al ronin sc. He probado con varios cables y nada. Le adjunto la imagen del problema que tengo. Gracias. Djbryan507@hotmail.com
2020-9-5
