Rendering settings for DJI editor
1704 5 2019-9-26
fans6765b5ea
Flight distance : 805751 ft
I have been shooting video at 24fps, but noticed when I do a quick compilation with the Go4 app, it ends up rendering the final outcome in 25fps. Furthermore, quickshots seem to be originally set to 30fps by default with no means to override.
So I have 2 questions that I hope to get help with:
1) Is there any way to change the output rendering to *24fps* in the DJI Go4 app?
2) Is there a way to change the default frame rate for quickshots?
Thanks in advance!
2019-9-26
DJI Tony
Hi, thanks for the inquiry. Please refer to the details below for generated resolution of the video upon editing in the application. We may need to confirm the query if you could modify the resolution with regard to the Quickshot. Thank you for your support.
DJI GO 4 for Android/ iOS:
If the original video is at the resolution below 1080p, 720p is generated after editing.
If the original video is at the resolution over or equal to 1080p, 1080p is generated after editing.
2019-9-26
fans6765b5ea
DJI Tony Posted at 9-26 15:57
Hi Tony,
My question was related to *frame rate*, not resolution. Please have a look and let me know if there is any way to change it. It seems to default to 30FPS for quickshots.
2019-9-30
DJI Tony
fans6765b5ea Posted at 9-30 04:58
Hi Tony,
Hi, we're sorry for the late response. I've confirmed this matter and the Quickshot feature should be on 1030p/30fps. The frame rate can't be changed. Thank you for understanding.
2019-10-3
fans6765b5ea
DJI Tony Posted at 10-3 14:00
Thanks for the clarification, I'll have to work with it
2019-10-16
DJI Tony
fans6765b5ea Posted at 10-16 07:25
Thanks for the prompt reply. we do appreciate your understanding with regard to this matter. Please keep us posted on the latest progress. Thank you for your support.
2019-10-19
