deathsquad
Flight distance : 6763835 ft
The edit video function doesn't really work well. I think that's why most people use something else to edit their videos. Can you make it so it edits like imovie where you slide the video slider to cut and shorten it and you can see where it is in the video as it plays as you scroll. The way it is now is too hard to use. You have to slide, wait, then see where you are up to in the video before sliding it again. It just doesn't work well without knowing where the cut is if it isn't showing you as you slide the end marker.
