Hello, first timer and to be honest really hard to get this set up and put vid in so hoping it is attached, nothing easy when your you not using continually
I am only a owner of this drone for a year and have done a dismal 200 flights but pretty restricted as others are,
But if you click on link following link you will see the front sensors working nicely, What you see is the sensors woking at this point,
I use the the drone for the purpose of sussing areas out and not for movie quaility as i see others are after and this is pure footage with no changes and no ND filter so dont knock me,
I was coming in low as stated in the app showing negative altiatude was raising and the machine stopped when got to close and this was at speed, very impressed with this system and found if i follow the rules in the manual this awesome machine behaves as it should both in P mode and tripod,
