I am missing the flat bottom :-(
887 4 2019-9-30
Is it just me, or does anyone else miss the flat bottom of the Osmo Mobile 2?
With the 2, if you just needed to put it down for a few seconds. you didn't need a stand, you could just place it upright on a table.  (See picture below)
With the three, it has a curved bottom so will only stand upright with a stand screwed into it.
Seems like an odd thing to do.
2019-9-30
DJI Stephen
Hello and good day marco.nice. Thank you for reaching out and for sharing your insight with is. With the new grip of the DJI Osmo Mobile 3, it is about a 15 degrees tilt down which makes the unit much more comfortable to use. In addition the DJI Osmo Mobile 3 needs the Osmo Grip Tripod or other compatible Tripods so that the DJI Osmo Mobile 3 will be able to stand on tables or other level surfaces so that it remains stable without tipping over. Thank you.
2019-9-30
Montfrooij
Flight distance : 2560453 ft
I can imagine.
Now you need an extra purchase
2019-9-30
DAFlys
I never used my Osmo2 like this,  Id be too scared it would fall over,  always used a small cheap ebay tripod in the bottom.  You can also use it as a mini selfie stick too.
2019-10-1
marctronixx
Flight distance : 210118 ft
The combo pack includes a stand. It was just a couple bux more.
2019-10-1
