DJI Gamora
Hi, thank you for bringing this query for us. You can download the DJI Assistant 2 software for you to check if there would be an available firmware for the said drone. You may refer to the link below. Also, please note that you can only download the firmware of your aircraft using the DJI Assistant 2 software. Therefore, you can only download the firmware of your RC using the DJI Go 4 application, you need to connect the mobile device of yours to your home wifi then run the app and check if there would be a new firmware update for RC. In addition, you need to download first the firmware of your Aircraft before the RC. Please don't hesitate to reach us if you have other inquiries or concerns. Thank you!
https://www.dji.com/downloads/so ... t-dji-2-for-phantom
