Drone footage looks a bit laggy
2551 7 2019-10-1
Heldegar
Hello i tried a new edit and when i exported it from adobe premiere it looks a bit laggy at the beginning.
It looks like my footage is jerky. At the begining if you stare at the wooden shack you will see it.
Is it a problem with adobe premiere or youtube? Have you ever had this problem?
https://www.youtube.com/watch?v=Aeq3IWx29IQ&feature=youtu.be
2019-10-1
Fre Mo
Flight distance : 803868 ft
indeed, jerky footage, this is not normal. Maybe a problem with the video frame rate. Do you record in 24p, 30p???
2019-10-2
Heldegar
Fre Mo Posted at 10-2 01:32
Hello in 24p on the original footage there is no problem
2019-10-2
Heldegar
i just look on properties in windows and it appeared as 29p *
2019-10-2
ttomas
Yup, JERKY AS TURKY,
Maybe it's the connection....
2019-10-2
ttomas
2019-10-2
CoollyMcAwesome
Flight distance : 274829 ft
the whole clip is really jerky from start to finnish, I think it was the way it was encoded in premier. Try to save it at a lower resolution, like 720p, then move up to 1080p. Maybe the preset you picked in premier was a tad high.
2019-10-2
Montfrooij
Flight distance : 2560453 ft
It has a lot of similarity to framerate error.
Where you render in 25fps, or even 24fps and the footage is (slightly) off.
Lower res won't help on this.
Rendering is not depending on the resolution (maybe the time needed)
2019-10-3
