djiuser_ChVJ6OAK8XeX
hello, can anyone guide me? I have a DJI P4P, was for many months asking for the update, but always without problems, after I finally give in and update, the problems with the drone were immediate. An apparent image interrupted, a gimbal turned sideways, lost connection command, when initializing of drone the connection with command or command became more collapsed, an image only appears after turning off the command 2 times ... Anyway. Downgrade, use another command, run upgrade ... Nothing dji recommends working. By this time, there is no connection between command to drone. I took a DJI representative and they said the issue was in the gimbal and only after opening they would know if the board is good. It is said to have detected an error in the camera sensor and a board error is possible (aircraft coding error). Gimbal replacement is 800 €. They say in a forum, they can try to turn the camera (off), gently to both ends, to automatically unlock anything... I don't know. Suggestions? |
