Mavic Air active track
635 4 2019-10-2
jeskew82
Hi, I just recently tried using active track for the first time. For some reason it is not recoginixing any of the objects I try and select. Any Ideas as to why this is happening? FYI im also using an ND16 filter at the moment, not sure if that may impact what the camera is seeing. Any help would greatly appreciated.
2019-10-2
SAMpSONNN
Flight distance : 377881 ft
Only thing I could of is that there needs be a significant contrast between the object you are selecting and what is behind/around it
2019-10-2
jeskew82
Yeah, I assumed that would be an issue. I went to a field in the middle of a bright day. It wouldn't recognize me or my dog. I've tried a few times but still no luck.
2019-10-3
DAFlys
I would test it without the ND filter installed.
2019-10-3
Neo Supreme
Flight distance : 76329 ft
DAFlys Posted at 10-3 04:55
Yeah.  The active track usually does a good job locking onto a subject/object, granted that it can be picked up by the drone properly and it isn't moving very fast.
2019-10-3
