FauxFilm
I looked through the forums and don't see a similar issue.
I just got back from a flight with my Mavic Pro and the camera controls were erratic.
I generally fly with the camera in "auto" mode, but when I booted up this time the image was waaay blown out and overexposed in auto. I powered everything down and re-started, and things looked normal for a bit... but then the problem re-occurred.
So, I thought, I'll just shoot in manual mode, which I probably should do more anyway. But, no joy... the exposures, even in manual, kept ramping up and down, brighter and darker. And since exposures instantly "click" up and down rather than smoothly ramping, it makes the footage unusable. I repeatedly kept having to go into the camera settings and readjust it, it seems primarily that it was the shutter speed that would not stick... I would set it to 40 (or 60 or whatever) and then after an exposure problem I'd go back in and look and the shutter speed would have shifted down to 25 or whatever... it wouldn't "stick."
Also, the controller is now fairly often and randomly "beeping"... I don't know if these issues are connected or not, but that is definitely new.
I'm using the CrystalSky monitor running the app, when I boot up it tells me I have the latest firmware.
Anyone got any ideas?
Thanks!
T2
