Olaio
Hello all
i have one OsmoMobile2 and use it many times almost full axis/motors range, in other way, almost all degrees range motor by motor,
so far so good
with OsmoMobile3, i cant use vertical range like described in OsmoMobile3 specs,
- Mechanical Range
- Pan: -162.5° to 170.3°
Roll: -85.1° to 252.2°
Tilt: -104.5° to 235.7°
my unit is very far away of it :/ running Iphone SE but the problem is not the phone,
45 degrees or minus for up and for down axis .
not hapy with it
Is this normal ??
will this be removed by firmware, or this limitation will rule as the unit being alive. ?
