A Sparky Update
1147 15 2019-10-4
SCoutts
Flight distance : 1922434 ft
Hello,
Sparky had a big crash. Sparky survived. This video follows up “A DJI Spark Story” and gives an update on the “health” of my DJI Spark. I go in to more details on why the crash happened, how you can prevent a similar crash, what damage occurred and how my Spark is doing in general. Make sure you watch to the end to see some of the footage I captured after my Spark got back in the air.
Thanks for watching!
2019-10-4
DJI Stephen
Hello and good day SCoutts. Thank you for sharing this video and for sharing your experience with us. These video will be a very big help to all our DJI co pilots in safely flying there DJI drones and on what to do if they experince the samething. If you have any issues with your DJI Spark in the future. Please do not hesitate to contact our DJI support team at https://www.dji.com/support?site=brandsite&from=nav for further assistance. Thank you.
2019-10-4
ssylca44
Flight distance : 434721 ft
Thanks for the update. Cheers from Kingston
2019-10-4
Wolferl
Flight distance : 23793 ft
Hi SCoutts
Being an electronic engineer let me tell you: forget about the trouble with the rice. It simply does not work. It does not remove humidity where it needs to be removed (from the PCB and electrical contacts).
It even makes things worse having rice corns and dust in the motors and gimbal bearings.
That rice thing is a false rumour since ever.
Putting everything in a bag is even worse. That way the humidity stays in the bag. No, the rice does not pickup and keep substancial amounts of water vapour.
The tip putting wet Sparky up on the dashboard on a sunny day is right though. Hot air keeps a lot more moisture than cold air, thats why it works.
Together with quick removal of batteries from the bird, that's the things that saved your spark.
Glad your Sparky survived!
Cheers,
Wolferl
2019-10-5
Montfrooij
Flight distance : 2560453 ft
Thanks for the followup!
2019-10-5
Montfrooij
Wolferl Posted at 10-5 01:30
Hi SCoutts
Thanks for the tips!
Hope I never need them
2019-10-5
SCoutts
DJI Stephen Posted at 10-4 13:11
Thanks very much! I appreciate you guys!
2019-10-5
SCoutts
2019-10-5
SCoutts
ssylca44 Posted at 10-4 13:37
Thanks for watching and cheer from Calgary!
2019-10-5
SCoutts
Hi SCoutts
Well, good to know. It's just always worked so I've just followed the same process. As you point out, it was likely the heat and not the rice doing the trick. I'm sure leaving it untouched for 48 hours contributes.
2019-10-5
SCoutts
Montfrooij Posted at 10-5 10:54
For sure, thanks for watching!
2019-10-5
Wolferl
SCoutts Posted at 10-5 19:02
Hi SCoutts,
Yes, patience is the key here. If the innerds are not fully dried up, corrosion will kick in and destroy the thing in short order.
Cheers,
Wolferl
2019-10-6
jacksonnai
Great to know that, thanks for sharing
2019-10-6
Montfrooij
My pleasure!
2019-10-6
DJI Stephen
SCoutts Posted at 10-5 18:58
You are very much welcome SCoutts. Please stay safe always and keep on flying. .
2019-10-7
DJI Stephen
You are very much welcome SCoutts. Have a safe and a happy flying always. .
2019-10-7
