Problems with Jerking video
1211 5 2019-10-7
F00nk
Hello together,Does anyone have any idea why some of the recordings are jerking so strangely?
Did i used the wrong settings?
Manuel Mode:
Full HD, 50fps, Color normal, Rocksteady on, ISO 100
https://drive.google.com/file/d/1oNIxDqw-NDe8GqibM9aLPq6WnvVQj_CB/view?fbclid=IwAR24joIfryDrUFLjTt57gUaFvPdoir-FLDxzru1AjOa4ZFrc428NN8btpJQ
All previous tips in the Facebook groups were not successful
Could it be a problem with the SD card?
I am currently using this one:
https://www.amazon.de/Transcend-128GB-microSDXC-Speicherkarte-TS128GUSD300S/dp/B07C9PVLN8/ref=sr_1_3?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&keywords=micro+sd+transcend&qid=1570436330&s=ce-de&sr=1-3
Thanks!
2019-10-7
F00nk
Sorry...the cam is the DJI Osmo Action
2019-10-7
Hi F00nk, sorry for the troubles, may we also have the logs for further analysis? The Osmo Action's camera logs are files stored under the /MISC/LOG/ Folder in the SD card directory. Please note since this is a hidden folder, if you want to view it, please turn on the hidden item view permission first, such as tick "Hidden items".
2019-10-7
F00nk
Hey Mindi,
i ´'ve sent you the link to the logs via PM.
Thanks and best regards
F00nk
2019-10-7
F00nk Posted at 10-7 08:30
Hey Mindi,
We appreciate your assistance to export the logs, the issue has been forwarded to our engineers for further analysis, we will keep you updated, please wait patiently, thank you.
2019-10-7
Thank you for your patience, Osmo Action can achieve the best stabilization effect in an environment with sufficient light.
1. Please adjust the shutter speed and ISO properly. We will get a better stabilization effect when the shutter speed is about 1/200 seconds. 1/500 or below can achieve the best stabilization effect.
3. Appropriately reducing the frame rate (below 60 frames) will also enhance the stabilization effect.
2019-10-12
