fansfe82067d
- Optimised performance after powering off by shortening the time taken to enter storage mode
- Optimised joystick control after switching to front camera
- Optimised performance when pressing the trigger 3 times to switch between front and back cameras
- Increased the endpoints of the pitch axes and added a reminder in the app before reaching the endpoints
- Optimised the joystick control speed
- Optimised performance when switching between follow mode and FPV mode
- Optimised performance when switching between upright mode and side grip mode
- Fixed some minor bugs
The most obvious improvement is that the pitch axis is now a bit wider, so you can tilt the handle roughly 60 degrees forward or back with the pitch locked, compared with about 45 degrees before (these are very rough estimates). The warning pops up just before you reach the point where further handle movement will cause the phone to be moved, so you can avoid spoiling your shot by unexpected movement in the pitch axis.
Otherwise, it's a matter of subtle 'performance optimisations' which subjectively improve smooth functioning of the device and general responsiveness. It seems to me that zoom is improved, but it's still a bit jerky - best used for shot framing rather than for live zooming.
