HereForTheBeer
Flight distance : 5381368 ft
i dont know if its bad focus or resolution (1080P on youtube) and underexposure is the issue but all of them looked blurry to my eye as well as pretty noisy. the +2 and +3 looked like was haloing around edges.
how i shoot on my mavic 2 pro is: 4K HQ 30fps (HQ is cleaner and shaprer then full frame mode), 100-400 iso during daytime lower the better, f/5 - f/8 aperture for sharper capture of wide open areas. shutter, either use ND filter and target 2x fps setting or if going bare, roll the shutter until scene is evenly light no bright spots. color profile: normal, sharpness +1, saturation and contract both 0 and 0.
pro tip to anyone wondering, yes it is better ti slightly underexpose then it is to over expose slightly, easier to pull more data going up in exposure then it is to pull same data going down.. true even with raw cameras and data. ideally best to nail lighting everytime if you can...but if you have to compensate in some way then slightly under exposing it then in post pulling up the shadows, and midtones and whatever else is needed will work better... |
