akozc
Flight distance : 2019951 ft
the_saint Posted at 10-15 07:28
^whenever you get the play store loaded on a device, there's always the potential to start adding apps. wasn't my original intention but over time, i'm starting to see it occur with more frequency. if the smart controller was better and smarter, there would be little need. anything that helps with your overall flying experience starts to creep in. only because i've added my gmail do i need to consider a lock function but all devices should be able to lock to prevent unauthorized access, no? if you can get to the playstore, you're potentially wide open even for apps that aren't yet downloaded, right?
Yes I do agree with Kloogee, suggest to keep SC away from all those power consuming apps including screen locks or other security apps. SC is not actually as powerful as ordinary Android phone and at the end may not perform well.
But agree also in this mobile device era ,you may not know where, when and how the intruders encounter with your device. If you installed gmail , then may be only option to protect is dont select the remember the log in cridentials.
DJI also consider this device as "Controller " rather than "Smart Apps Mobile Device" may be therefore never considered to add Auto Lock option ( imagine in mid flight device is locked and does not let u unlock)
