HereForTheBeer
Flight distance : 5381368 ft
hallmark007 Posted at 10-14 04:33
It’s almost impossible to calibrate a M2 wrong, same with mavic air if you calibrate wrong it will continue to show warning, so calibrating won’t do any damage, you will have noticed certainly around here almost no crashes because of bad calibrations, I agree with you sensors must be set very sensitive to show this warning so regularly, but I have weighed up the simple fact that I have never got this warning with Mavic Pro but many mavic pro crashes were due to taking off with bad compass, so for the time being I’m a lot better off , hopefully dji will work on setting this sensor with less sensitivity , but if they do it must result in the M2 keeping its record for little or no crashes from calibration.
in theory it should, however nothing is perfect and more often it false positives and people just calibrate every time on the spot the more chances that gives for it to one day accept a poor calibration. im sure thats happened on rare occasion and triggered a fly away. i bet you anything that's why my first spark on failsafe RTH turned the wrong direction and flew away luckily crashes itself before going to far.
for me, this behavior really started kicking off in latest firmware which furth indicates is a software issue not hardware. personally on my mavic 2, if my compass sensor reading in app is low enough and the direction my drone is facing matches actual direction then i ignore it and launch it. honestly it will eventually stop reporting that error after a short while and its almost random when it errors.. i haven't figured out the pattern.. sometimes a reboot fixes it, sometimes rebooting it and moving it to another location fixes it, sometimes just ignoring it long enough fixes it. so far im not forced to calibrate inorder to take off which is a positive and please dont change this DJI. because it drove me absolutely insane on mavic air with it being compass error = grounded until recalibrated or if slick enough sometimes take of before finished booting using stick method to arm it and right away pushing up to get ahead of the compass erroring out nd it finishing booting.. |
