Ronin-s wobble
1216 5 2019-10-13
slugger415
My Ronin-S shows a horrible wobble whenever I pan or tilt, taking half a second to stabilize. Here's a short clip with the camera standing on a table and I'm just panning with the joystick.
What's going on? thanks.
p.s. balance shows Excellent for all 3 axes.
2019-10-13
Hi slugger415, what camera are you using? It seems the lens was zoomed in. Does it happen in the long focal length end?
2019-10-18
slugger415
DJI Mindy Posted at 10-18 01:55
Hi Mindy, I am *only* using it with the lens extended, I’ve been using it that way all along without that wobble problem. I also reset it to factory defaults but the problem persists, even with pan speed set very low and just the slightest movement of the joystick. The device is useless to me now. Scott
2019-10-18
slugger415
p.s. it's a Canon 7D. And I've balanced it with the lens fully extended with "Excellent" on all axes. Thanks.
2019-10-18
slugger415 Posted at 10-18 10:17
Will it wobble without extending the lens? It is recommended to balance the gimbal in the middle of the focal length.
2019-10-19
slugger415
DJI Mindy Posted at 10-19 01:44
Yes it does it at all lens settings. And this is NEW behavior, I have lots of footage to prove this was not happening earlier.
2019-10-19
