Battery Damaged / Battery Cell Damage
776 2 2019-10-14
DennisM
Flight distance : 387733 ft
Have received this alert several times now after taking flight 5 to 10 minutes into the flight. Have returned to home immediately with no harm. Today I stayed out an extra 10 minutes to finish an assignment then returned without incident. This time I checked the status of the battery cells and they all read 3.92v.
Thoughts on the problem? Should I just replace the battery? My second battery 11aa battery flies without a problem.
2019-10-14
DennisM
Thoughts on the problem? Should I just replace the battery? My second battery battery flies without a problem.
2019-10-14
DJI Susan
Hi DennisM, may I know which DJI product do you refer to? As for the battery cell issue, have you tried to discharge the battery and recharge it fully to check? If yes and the battery is under warranty period, we're sorry that you may start a case to send it in: https://www.dji.com/support
2019-10-14
