Eric19
Hi All
Read some feedback on the battery issues.....but not what I wanted.
Here goes, my P4P V2 is 14 mths old, recently the original batteries started to expand. Was told not to use, so I bought new batteries. After charging the new batteries, put into the drone and guess what, Cannot Take Off sign appeared, overall status read, "Battery not installed properly, unable to take off. Check and reinstalled battery."
Read up on the froum, some says contact point issues, just push it in again should be fine. Well, I did that and the "Cannot Take Off" sign disappear. Horray, I thought it was solved. Once I take off, darn, the rear green blinking light turn into solid red. Everything elase on the screen looks normal. Since it was showing red instead of the normal blinking green, decided to play safe and not to fly.
So, does anyone have the same issues ? What can I do so that I can fly safely. have feed back to the vendor, they says they will check with HQ.
One thing though, the batteries works well with my Version 1 P4P pro. Thanks for your reply.
Battery not install
Cannot take off
Gap
