But is there no way to save the charging mode setting on DJI go 4? Every time I exit the function it is un-enabled, before it was not so, can I insert in DJI go the possibility of saving them between personal settings?
imposed charging mode on DJI GO 4, the setting is not memorized, at every start it must be set, before it was kept in memory, I asked how to obviate this
Do you mean the setting that allows the controller to charge your phone? If so this works fine for me with iPhone, perhaps you are on android and then it cannot be turned off.
If you are using ios devices it should be automatically memorized (i.e do/dont charge the my mobile device)
If u use android device, this oprion does not work what ever u do your mobile device will be charged by the controller it is not DJIGO problem but Android system limitations.
Charging Mode has now been changed in the New Firmware Update for the Mavic 2 series.
You can now change the Number of days before discharge starts - it was originally 10 days but too many Batteries are now Bloating and after 6 months DJI will not offer any help.
Suggest you now set to 3 Days.
I think he's talking about the charging issue with the controller to the device he is using.
And we are waiting to find out if he's on IOs, or Andyroids....
Andyroid, nuthin to do.
IOs, I believe it's a toggle somewhere in the system....
