DJI Gamora
Hi, thank you for reaching out. If you are using the DJI Go Editor it is normal that the cache file in the mobile device has no sound and it is normal that the DJI Go Editor will automatically provide its audio adds. Therefore, you can check the video file that was inside the SD card since that file has the original sound and you can edit that thru 3rd party application. Hope this helps. Thank you for your continued support! |
