Gimbal Calibration stuck at 50%
1299 6 2019-10-17
BadgerPhotograp
My gimbal calibration is stuck at 50%. I have latest firm ware and have tried to recalibrate imu. imu recalibrates but gimbal just stuck at 50!! help
RedHotPoker
Flight distance : 165105 ft
I don’t know if chilling the drone first, works with your model, but we used to recommend that frequently, with the troublesome Phantom 3 Pro that some members had..
RedHotPoker
2019-10-17
DJI Gamora
Hi, thank you for reaching out and we're sorry for the inconvenience. May I please ask what happens prior to the said issue occurs? did you experience any hard landings? You can try to sync all your flight records in the application then try to uninstall and reinstall the application then perform the gimbal calibration again to see if the issue persists. Please keep us posted. Thank you!
2019-10-18
joakim3
Flight distance : 4335463 ft
Sweden
2019-10-18
joakim3
Sweden
The grease cable from the camera must be bent at 90 degrees directly from the camera housing down to the shaft, otherwise it will get stuck in the motor
2019-10-18
joakim3
Sweden
2019-10-18
joakim3
Sweden
I use extra glue that you see and that did the trick
2019-10-18
