Tony
Flight distance : 2856060 ft
In theory you can fly with the iPad only, although I don't think I would ever attempt it. You need to be able to take over at any moment, in case things get hairy. But from what I can imagine, it is quite possible to use only the iPad. You would definitely want to set your 1st waypoint directly overhead, as the quad will be on it's way to the first waypoint as it ascends from the ground, so anything in it's path will be a hazard. |
