Ronin SC won't connect to Bluetooth
15865 11 2019-10-20
HRDMN
Hey there,
i just received my Ronin SC. Unfortunately it won't connect to bluetooth with my Huawei Mate 20 Lite.
The SC can't be found by the app even though it appears in my list of bluetooth devices.
Any help is appreciated.
Thanks
Andreas
2019-10-20
Hi Andreas, please make sure there is no other Bluetooth turned on, then do not connect to Ronin-SC's Bluetooth on your Bluetooth Settings. Enable Bluetooth of your phone and enter Ronin APP, search and connect directly.
2019-10-20
djiuser_RrbmDCvLTFrW
Hi, I Have the same problem I can't connect ronin with my Samsung s8+ it's showing me it can't connect with the device ...
I restart my phone and ronin 100 times ....
2020-12-15
djiuser_Y41a40FUHF4a
India
Hi,My DJI Ronin sc buetooth not connecting whith my device
I am tried with another device but same problem.
And my joystic not working
Please tell me what happened
2021-10-25
djiuser_AiKjGCDc5v9p
DJI Mindy Posted at 2019-10-20 23:18
I am having the same problem with a Samsung Galaxy S8+.  Have tried everything.  Did just as you said and have no other Bluetooth devices on. Still can't connect.  My phone does show the Ronin in Bluetooth when it scans so I know the phone is not the problem.  Please help!
2021-12-28
djiuser_AiKjGCDc5v9p Posted at 12-28 16:20
Could you please download and reinstall the app through the link below? Please make sure to allow for all app permissions when installing. https://www.dji.com/downloads?site=brandsite&from=nav
You may also go to the mobile phone's System Settings - Bluetooth and delete the matched Ronin-SC and restart the mobile phone to see if it works.
2021-12-28
Lee-rus
Flight distance : 315223 ft
Russia
Hey!
I can't connect my RONIN SC to my phone. My phone perfectly sees this equipment through bluetooth. But at the moment of connection, my phone tells me: "RONIN does not allow pairing".
2022-1-21
Lee-rus
Russia
Lee-rus Posted at 1-21 03:28
Hey!
[view_image]I can't connect my RONIN SC to my phone. My phone perfectly sees this equipment through bluetooth. But at the moment of connection, my phone tells me: "RONIN does not allow pairing".
Problem solved.
I downloaded the app from this link. My equipment works great.
2022-1-21
fans90503f45
DJI Mindy Posted at 2021-12-28 20:21
I done everything its been told here, but when i try to download the app from the link, it says document cannot be open.
2022-6-17
fans90503f45 Posted at 6-17 20:58
Hi there, may I ask if you're trying to install the DJI Ronin? Could you please check if the 'Allow from this source' option of DJI Ronin is enabled? Please find the setting of "Install unknown apps" in the phone system settings, and turn on the switch of "Allow from this source" and restart the phone and then go to the file manager to open this file again to see if it works.
2022-6-21
JattyThomas0121
India
DJI Mindy Posted at 2022-6-21 01:59
I searched on every forum on internet and eventually end up fixing this by forcing connect the headphone. https://thegeekpage.com/how-to-f ... -in-samsung-phones/
2023-10-10
Laurens H
Hi, I have now a Sony a6700 which I can't connect to my Ronin SC. Cable connection is not working. Is there a way to connect through Bluetooth and if so where can I find the pairing etc on the Ronin app?
2023-10-14
