KlooGee
Flight distance : 15944757 ft
jcdonelson Posted at 2-5 14:03
Very bad idea. There is a special version for SC and CS. DO NOT DO THIS. The SC will update when it's version is ready.
Firstly, this is a bit of a moot issue because DJI has released a new firmware update that has a newer version of DJI Go 4 than the one discussed in the video. I'd recommend updating to the latest firmware instead.
Having said that, I will disagree with your opinion on this. The recommendation to update to the latest APK from the DJI website came directly from DJI Support. I just provided the easiest method to make that happen.
Also, there is a very large number of people that used this process very successfully without problems. That includes myself. I had a huge number of flights using the version of Go 4 discussed in this video without any issues at all. In fact it worked much better than the previous version I upgraded from.
To be clear, the CS does not allow this to work because it apparently does need a special version. If DJI didn't want this method to work, their support team would not have recommended it and the SC would not allow it to work.
