Manes F
djiuser_jB4hjwRUmRam Posted at 10-28 17:57
We spent a whole day trying to make it work, we had plenty of satellites visible, moved it to different places, eventually it worked when we were just giving up. We figured out how tho, as we were giving up, we just launched the drone (manually) to take a few pics with what was left of the battery. Try the following:
Turn on the RTK Base
I had the same problem this morning. I solved it, as it usually happens with DJI, using what we call the X-FILEs method.
First I turned the M210 off. Then I turned it on again. I updated my home point and once more I checked the perfect status of RTK. I decided to fly around 400 m far and then I requested a RTH. This way I checked RTK was going perfect since it landed in the lines I have painted on a EPS piece (I know, I know, it is absolutely irrational 8-)).
After landing, I opened the mission section in DJI-PILOT and voilá, everything worked perfect. No more fusion errors.
To be honest, I have the whole set of disasters and I am absolutely fed up.
One of the Z30 cameras does not correctly perfom initial calibration. It is.... let's say Lazy. Maybe 10 minutes after starting the M210 turns around itself and finally works.
I have 2 Cristalsky that I have to use with a really expensive pen for Ipad because of the terrible lack of sensitivity of the touchscreen and the lack of computing capability of the dammed monitors. My Galaxy Tab 5 runs faster mission drawing than Cristalsky monitors.
With SRE active, I NEED IT, batteries barely reach 2 hours and I have even had a hung up in the camera operator monitor. By the way, the monitor seemed a toaster.
XT2 have fisheye effect.
My god!!!, how can it happen with a 25mm lens and 8 mm 55º FOV in visible? It is perfect for our algorithm to automatically georreferencing faults in solar panels.
We have a work in Morroco. Perfect: cold weather, no need of SRE and maybe the RTK does not fuse with whatever it has to fuse.
I think we all need to say a prayer before flying any DJI product. The more expensive the worst.
Good Luck from the north of Spain!
Manés
P.S I have to do many more tests. I will keep you updated
