Cetacean
Flight distance : 2528264 ft
Aloha Infinity,
When you have calibrated the right stick, has the percentage of completion display gone from 0 to 100%? My P4 has required five or ten seconds to budge from 0% and numerous efforts to calibrate from 0 to 100% but it eventually gets there. It just takes patience in my case.
The completion display has to reach 100% for each stick direction and all along each track. The numbers in the completion display have got to change with the progress of each stick along each directional track. So, you will have to look and concentrate on each stick direction as you calibrate each stick and the wheel. I have even found that jiggling it a little helps to get it moving and keep the numbers responding. There are also various locations on the direction track that can be more responsive than others. When that happens, you have to do another calibration and make sure that the full track is responding to stick input.
I have not gone so far as to use contact cleaner, but you might want to see how what I have noted works out first. And then you might check with DJI to see if contact cleaner will be helpful under your specific circumstances.
Hope this helps!
Aloha and Drone On! |
