AntDX316
Flight distance : 3394731 ft
The one with no red lines shows a perfectly straight bottom screen. The others have the bottom area with completely deadpixels? and no floor or ceiling. Is everyone elses DJI RE goggles on the right eye section the same where the left is perfect?
It's a 9/2019 mfg date. People are saying they lose connection within 900m but it was able to go out 1500m in HD. Distance limit is 1500m and didn't bother to go further.
Edit: Flown and I don't even notice it at all. The feed quality is crisp enough on the M2Z to make out what you are looking at with sharpness. This makes the M2Z more enjoyable as a for fun drone. The gimbal headtracking can be interesting at first but because the tracking resolution being bad, it's not smooth so zoomed all the way in at 96mm it will show you what I mean. I had a small window of no rain to practice a bit before it started to rain again. If you have the money, definitely get one but if you are going to use for Professional work that doesn't involve some sort of "recon", the Smart Controller alone is more ideal |
