osmo pocket waterproofcase warning
8884 20 2019-10-28
fans70cad27e
Indonesia
When I connect de wifi I al the time receive a warning that says.: osmo pocketwaterproof case mode. Please insert osmo pocket in waterproof case/exit waterproof case mode. when ever I exit the mode the warning immediatly comes back. What is going on?
2019-10-28
DJI Tony
Hi, we're sorry for the inconvenience. I would like to ask if you've done uninstalling and re-installing the DJI mimo app to see if there will be changes? May we know if you manage to update the firmware of your Osmo Pocket including the app? Would it be possible if you could provide us a video showing the problem which also includes that you've turned off the waterproof case mode? In addition to this, it's recommended to save important files before deleting the application. Please keep us posted on the latest progress. Thank you for your support.
2019-10-28
djiuser_MfPFrIlm7HCs
Philippines
I am also experiencing this.
2019-11-5
Philippines
DJI Tony Posted at 10-28 07:32
2019-11-5
DJI Natalia
djiuser_MfPFrIlm7HCs Posted at 11-5 12:41
Hi there, may we know the specific issue you had encountered? Please kindly let us know the details and we will do our best to help.
2019-11-7
DJI Natalia
Hi fans70cad27e, may we confirm that have you solved the issue or not?  If the issue still persists, please provide the below information for further analysis:
1. The specific time of the issue happened.
2. Export the log after the issue happened: MISC/LOG/camera_log.log + gimbal_log.log + emergency_log.log
2019-11-7
Youri Mahieu
Belgium
Hello,
Same problem here when i connect with the app through wifi.
Can' t use the osmo pocket.
greetings,
Youri
2019-11-25
djiuser_57yBQP9nNKC6
Flight distance : 161565 ft
Ive got the same issue, and I cant seem to sort it. What can I do?
2019-12-3
Stephen Purkiss
djiuser_57yBQP9nNKC6 Posted at 12-3 12:34
Ditto, very annoying!!!
2019-12-4
Bennett.denny
Same thing.  Uninstalled Mimo several times and tried firmware update several times (uninstalling each time)....the firmware update version shows V01.09.00.20.  It would get to 45% and I'd get some error code 241, try to "retry" and get error code 245.  Finally on the 4th time, it looked like it was going to go through, got hungup at 60% and said on my phone something about device failed to restart.  But then on the Pocket, it was blinking red/green and showed a % that continued to increase.  It finally got all the way through it on the Pocket and turned off and back on.  Now it seems to be working ok and that waterproof message is now gone.  I understand with firmware updates they can be clunky.  This sure was.  Took a bit to try, uninstall, reinstall, sign in, connect, etc. but it looks to be working.
2019-12-4
stephenpurkiss
Sweden
Stephen Purkiss Posted at 12-4 04:05
Think I made a rookie mistake - didn't check I had the latest firmware.
2019-12-14
mengteck71
Singapore
I have the same issue too.. please help
2019-12-14
djiuser_GgTvc7tSgPML
Taiwan
same here!
how to settle this error?
2019-12-28
Taiwan
2019-12-28
Curt1591
Thailand
Youri Mahieu Posted at 11-25 01:17
Hello,
Possible solution?
2019-12-28
djiuser_wODA075Ck2a1
India
I have the same problem. I went to update the software but the warning kept popping up. Is anyone from DJI even looking at these forums,?
2020-1-4
fans70cad27e
would be nice if it was that simple. But the warning comes back directly
2020-1-8
Juju09
Ukraine
The same
2020-2-1
fans70cad27e
This problem comes together with the fact that I am not able to connect the Cosmo pocket with my I phone using the connector. Resulting in the problem that I am not able to update. Could this be related?
2020-2-1
djiuser_YWuq4Z9KH7to
Pakistan
I am facing same waterproof case warning , its useless now
Pls solve the issue
2020-4-18
rcupido
Singapore
Hi everyone, has DJI provided a solution for this? I can not use my Osmo Pocket for more than a year on remote mode with phone, is basically became useless for what i used it most: long time lapse videos. anmy advice? r
2021-4-18
