Montfrooij
Flight distance : 2560453 ft
There are some factors regarding the frequency too.
- 2.4ghz is a lower frequency so it's less directional than 5.8ghz. Meaning, 2.4ghz radio waves will go around and through objects a bit better than 5.8. So if you start to descend below the horizon, or a bunch of trees gets in between you and the drone, etc., 2.4ghz will be a little more forgiving. 5.8ghz, OTOH, will tend to do the opposite; it's more easily blocked by obstructions, hills, etc. that intervene between you and the aircraft.
- more bandwidth is available on the 5.8ghz band, I believe, so the transmission will be a little better quality. At least in theory, I haven't actually tested this yet with my P4P, but it makes sense.
- 5.8ghz has less other traffic on it than 2.4ghz, so you're less likely to encounter interference on the 5.8ghz band. |
