Mavic Mini with DJI Goggles
79470 353 2019-10-30
DJI Gamora
djiuser_jHwh0elkAMI4 Posted at 11-27 14:31
Omg ,very very very thank you!!!!!!!!!!!!!!!!!!!!
You are always welcome. Thank you for your patience and understanding. Cheers!
2019-11-29
RUSH75
Dixcentimes Posted at 11-20 08:37
I will buy the Mavic Mini only if ​​it is compatible with DJI Goggles and that's it...
A few thousand more requests and DJI will do it
Yep, I think the same!
2019-11-29
RUSH75
DO you have any clue when Googles will be compatible with Mini? I would like to buy MIni for Crhistmas
2019-11-29
mfor1000
I just purchased a mini and it looks like it uses 5.8 GHz.   I also have a set of the new FPV goggles for my racing drones and it works off 5.8 GHz also.   It would be great if these would be compatible with the mini.   You might pull some of the racers and freestyle guys who would also like to have a cinematic drone for macro shots and general exploring.
Thanks!  love the products...
2019-11-30
GerdS
Flight distance : 4303379 ft
mfor1000@yahoo. Posted at 11-30 04:39
I guess you have a microwave oven in your kitchen, do you? These devices usually operate on 2.4 GHz, but too bad, although allmost any DJI drone supports 2.4Ghz you cannot use your drone remote for controlling your oven...
2019-12-1
djiuser_PJAU9P5sQd14
GerdS Posted at 11-25 00:55
I have a Mavic Pro as well as the white DJI Goggles and since a week I also have the Mavic Mini. I also would like to fly it using the DJI Goggles and I already tried to connect them via OTG cable, but without luck.
As I was aware of that problem from that moment where the new DJI Fly app was introduced, I thought about other options for goggles and found a solution for me. By far not as good as the DJI goggles but it works, at least until DJI does their homework with releasing a compatible goggles firmware.
[Image]
Just purchased the mini and was considering this option due to no goggle support. Glad to know it works. Also considering using a broken fpv headset that I have with a single fresnel lens to just magnify the phone screen
2019-12-1
as an engineer I understand that nothing happens overnight and timelines don’t always line up perfectly but I would like to add a respectful request for this feature. That being said, hope you guys are working it and ideally hope it is just a software update as I have already ordered the mini. As with many I have been flying a 250 fpv quad and the price point on this finally made sense to switch so I’m sure there are many potential customers like myself. Good luck!
2019-12-1
ro_flyer
Flight distance : 7557283 ft
Brazil
nope .......
2019-12-1
AntDX316
Flight distance : 3394731 ft
If you stick the DJI FPV camera system on top of the Mini then you can FPV.
2019-12-1
Captain....Kirk
Flight distance : 19094 ft
Impressed with the mini. Once it has goggle support it's on my A list of kit to aquire.
2019-12-2
djiuser_Fk3PdTl0GMOs
Hola, para cuando estara resuelto el problema de comapatibilidad con Googles
2019-12-2
djiuser_J02lF3DGRL4f
Hi.im really hoping you will make the dji re racing goggles compatible with the new mavic mini or even with fatshark would be nice so we could save a little money using our existing equipment.
2019-12-4
fansfa0cc3e4
Please let me know when goggles are available for the Mavic Mini and I'll buy some. Thanks
2019-12-5
Jason51873
Flight distance : 175463 ft
Mavic Mini really needs goggle support!
2019-12-5
Jason51873
DJI Gamora Posted at 11-5 14:24
Hi, thank you for bringing this query to us and we do appreciate your feedback. In addition to this, I already forwarded this request feature to our designated department for attention. Thank you for your understanding and support!
Yeah lets get this request fast tracked - its called a "Mavic" the entire Mavic line should support goggles regardless if this is an "entry level" drone. I actually am using it for professional work due to its size and weight class, and for my clients I only need 1080p video so the Mavic Mini is more than enough for my purpose.
2019-12-5
DJI Gamora
Jason51873 Posted at 12-5 14:06
I will note this request of yours. Thank you!
2019-12-6
pedzsan
Flight distance : 153625 ft
I too would like to use DJI's googles ... although I'm a little confused how it will work.  Folks have mentioned a cable but the new controller only has one port.  I guess I will find out when they finally implement it.
2019-12-6
Dano99
Definetly would like to see goggle support as well
2019-12-6
fans9af54f79
I will not purchase the mini until it has Goggles support.
2019-12-7
Thales
I had a mavic pro, and now have a mavic 2 and have always been on the fence with the goggles - if the mini worked with the goggles I would be ordering both right now. Thanks!
2019-12-8
Hulk2006
Flight distance : 16850 ft
I am another voter here and I would buy your goggles if they were compatible with Mavic Mini. Since your goggles are not compatible with Mavic Mini, are there any other goggles I could use?
2019-12-10
djiuser_6eybsn2ZJnax
DJI Gamora Posted at 10-30 09:08
Hi, thank you for reaching out. As of the moment, the DJI Mavic Mini is not yet compatible with the DJI Goggles since this product is an entry-level that is used with our brand-new application, DJI Fly. However, we will continue to optimize the product according to the customer's requests. Also, we will directly forward this suggestion of yours to our designated department for attention. Thank you for your understanding and support!
Yes please.  I vote for FPV on the mini!
2019-12-11
djiuser_sAPXxG1aA7mU
Russia
+ 1 I want mini to work with my Googles RE. no compatibility no mini
2019-12-11
Jason-Jenny Fawks
I also want to add that this is a deal breaker for me. I will buy the Mavic mini when it has FPV goggle support, or I will wait until they come out with a new version that does.
2019-12-11
djiuser_i3DwftHureDU
Flight distance : 2205 ft
Romania
Come on DJI! Let's make this dream possible also! Mavic Mini & Goggles!
2019-12-11
Alevpi
Flight distance : 43560 ft
Russia
djiuser_i3DwftHureDU Posted at 12-11 11:08
I think that with almost 100% probability they will not make it compatible!
Even if the Crystalsky controller says that it will not be compatible!
Apparently the "effective" managers came to the DJI team, who did not allow intelligent engineers to work!
2019-12-11
Jason-Jenny Fawks
Check out this response from DJI. They ARE working on it! Cool!
Hi Jason,
I appreciate you writing back and letting us know that there is an app that has a possibility of supporting VR once we've made a software update.
For this one Jason, since the app you're referring to, Litchi, is a third-party app, we cannot guarantee the full functionality of the aircraft as it is not tested by our Engineers. Also, I cannot confirm to you yet when will the VR Option on the DJI Fly App and Mavic Mini will be available but rest assured that it will be announced on our website and let's hope for the best that it will be out soon.
I understand that it is the main thing that is holding you back from purchasing the Mavic Mini and rest assured that we're doing our best to add more features and support with the equipment. We appreciate your patience while we're working this one out.
Should you have further questions or concerns, please do not hesitate to let us know and we're always here to help.
Thank you for choosing DJI.
Best Regards,
Pat
DJI Technical Support
2019-12-12
DJI Gamora
djiuser_6eybsn2ZJnax Posted at 12-11 05:19
Already forwarded to our designated department. I will keep you updated once we have the latest news from them. Thank you!
2019-12-13
djiuser_CF8KplrEfOQZ
I want googlea for Christmas please make it happen
2019-12-14
fans652d5e63
Hi Dji Admins and users !  Just received my Combo fly more, the mini is an awesome drone. Very satisfied and impressed. U guys at Dji made a great job. Now, to have the best experience possible we just wait the update allowing to use the Dji goggles ;)
If the jason's post is true, it's simply fantastic and proves how really Dji listens their customers !!
I'd like to know which Dji goggles model would suit the best with the mavic mini in the case of a later update firmware release?
(btw, a big thank you to the Dji team for the good work they make on this forum)
2019-12-15
Jason-Jenny Fawks
fans652d5e63 Posted at 12-15 00:37
The more people posting here will help them to put it as a top priority to enable VR goggles for the Mavic Mini!
2019-12-15
Good guy Biker
Flight distance : 459144 ft
this was a deal breaker for me guess i'll be returning it once it arrives
2019-12-15
Roger Dedos
no DJI Goggles support yet??? very bad DJI...very bad.
2019-12-15
Hover-Fly
Flight distance : 2425 ft
The mavic Mini does not have the necessary Occusync capability , so sadly, no.
2019-12-15
Jason-Jenny Fawks
Hover-Fly Posted at 12-15 22:26
Doesn't the spark use wifi instead of Ocusync and yet it has FPV capabilities?
2019-12-16
maazetic
Flight distance : 185184 ft
I cant wait for DJI to have the goggles connection work with mini. I was about to purchase the DJI FPV goggles but will have to wait
2019-12-18
djiuser_o8HHMeruEKtJ
I vote as well of course!
My question is, if/when goggle support comes to the Mini would this also allow something like the Oculus Go? or any type of goggles you simply slide your cell phone into?
2019-12-22
Armored_22
Not to my knowledge. It sounds like its still being worked on.
2019-12-22
avelkov
Flight distance : 493944 ft
Bulgaria
I'm also really interested in having VR for the Mavic mini. Please make this a reality!
2019-12-25
AE1M
Flight distance : 1862884 ft
As a new drone flyer, and MM is my first, how can one comply with FAA regulations regarding visual line of sight if the remote pilot is wearing goggles?  Do hobbyists generally just ignore this?  I have no idea how anyone can see this little white drone at altitudes about 200’ even a few hundred feet away!
2019-12-25
