JEZ2
Flight distance : 336204 ft
I think the rules are pretty clear if you read through all the FAA documentation. In my opinion, there is no exemption from part 107 due to weight. There used to be exemption from registration due to weight (and even that language has disappeared from the FAA guidance EDIT - but not on the registration site as it was pointed out in an earlier thread),
I base my opinion on the following:
1 - The Part 107 rule makes absolutely no mention of a floor to the weight and you will find no reference to the 250g or 0.55 pounds in it.
2 - The Part 107 discussion by the FAA mentions that there were comments around exemptions for those under 4.4 lbs. The FAA said that was something that was considered and would be looked at in the future.
3 - An ARC report in 2016 after 107 was implemented recommended that it be considered that 107 be modified and that under 250g (called category 1, they had other categories with other rules) would be allowed to fly over people. The recommendations stated that all other limitations of 107 should still apply to Category 1. If those were already exempt, why would the ACR need to make recommendations to remove flight over people?
4 - The FAA in March of this year, restated the idea that the new final rule will change by having categories, including Category 1 weighing less than 250 grams to have different fules.
So, in my mind, it seems pretty clear that the FAA does not think there are currently any special rules for UAS under 250g, otherwise they would not say they plan to have some expeditions for them in the future. That plus the fact that neither part 107 nor the new congressional law say anything about a floor for the weight and only consistently talk about "under 55 lbs" with no "and over", leads me to take an educated guess that there are no exemptions for part 107 due to weight at this time.
Additionally, it appears likely that there will be in the future, but that is only relating to the restrictions on 107 flights (such as allowing flights over people), and not the 107 process in general. |
