HereForTheBeer
Flight distance : 5381368 ft
internally onboard with the mavic mini doing all calculations? unlikely. one of the areas dji scrubbed out which helps cut down on power consumption by not using such a powerful system on a chip or a downclocked existing SoC and lack of sensors. but that being said, the litchi app added activetrack to unsupported drones a while ago using the main camera only and your smartphone to do reaction based path following, not sure ever did avoidance as well as requires a lot of compute power nd a quick connection time (low latency) and back in P3 and earlier days a powerful enough smartphone or tablet was not as common place. additionally activetrack 3,0 runs externally via the dji go app on some gimbals currently, so looks like dji maybe preparing for pushing activetrack externally more and more since smartphones are getting so much more powerful year over year it make sense.
all in all, yes it is possible dji could add some basic form of active track using the app and connected smartphone where just follow you around with main camera and does some very basic reaction based following stuff. but for them to add avoidance + tracking in a way probably be safer for this market at same time would require a powerful smart device as has to do path prediction to avoid things before encountering them and losing the subjct.
will dji? i dont know, dji is a bit of mystery sometimes.
