Ronin S Focus Wheel not setting lens range
800 1 2019-11-1
Carlos Niembro
Mexico
I'm using a Sony A7III with a Sony 85mm 1.4 G master on a Ronin S, conected to the camera with the C cable (I also tried the multi function cable). The lens switch is turned to AF but in the camara is set to MF. I also turned off the control with smartphone option and the USB conection is set to PC Remote.
The wheel actually pulls the focus, but it takes countles turns to pull the total range of the lens. I tried pressing the button, set position A and press it again for postition B but it didn't work.
Please advice!
2019-11-1
Hi Carlos, the focus speed can be set from 1 to 100 in the APP, did you try to speed up the focus speed to see if it helps?
2019-11-2
