adamaucock
Hey guys,
Just got my Ronin SC and am pretty happy with the performance so far (minus some weird production choices). My issue has come when using the app to check the gimbal balance. No matter what I do the Yaw/ Pan axis always returns as 'Re-Balance Needed'. I've got the pro combo so have tried it with and without the focus motor but this doesn't seem to change anything.
There's a range on the Yaw/Pan axis slider (from around 1.2 to 2.0) where the gimbal does not move when it is leant to the side as shown in the tutroials. However, nowhere within this range does the app accept this as balanced. There's no guidance in the app other than the video tutorials that aren't really helping in this case. I've tried deleting and redownloading the app but this didn't work. From what I can see there are no updates to the Ronin firmware and there doesn't seem to be a way to reset it from scratch or something like that.
I saw some other posts about the Ronin S having a similar issue and the DJI rep said that it was fine as long as the power level on the Pan axis motor when the device is leant to one side did not exeed the range of -5 to +5 however, mine frequently does at just 1 or 2 degrees of lean.
Please could someone help me work out what this issue is, is there a trick to balancing this axis that I'm not doing (and isn't shown in the tutorials)?
Thanks in advance,
Adam.
