Simple “turtle” type commands?
1218 6 2019-11-3
gpvillamil
Flight distance : 210226 ft
I want to set up some simple "turtle graphic" type examples for a class, and I was wondering if there some basic commands for turning x number of degrees, then moving forward in the resulting orientation for a given time.
Most of the chassis commands seem to incorporate multiple parameters, such as heading and duration one command. I could use simpler commands for teaching, eg
Number of sides = 3
Repeat for number of sides
    Turn right 360 / number of sides
    Move forward for 1 second
Do you know if this is possible?
2019-11-3
rhoude57 - YUL
I think this is what you are looking for:
2019-11-3
gpvillamil
Thanks, that seems to work well. I have a Sphero robot with an IMU, and on that one I need to read the existing heading and add the turn angle.
On the Robomaster S1 the turn seems to be relative, which is good.
I notice an odd thing: it pauses for quite a long time after the second turn, I wonder if it is waiting for the IMU to settle down or something.
2019-11-3
DJI Tony
Hi, we're glad that you've managed to figure out your concern via the help of our DJI Forum member. Should you have further concerns, please keep us posted. Thank you for your support!
2019-11-3
gpvillamil
Here is the equivalent for a Sphero RVR - since it makes its turns using absolute values, I have to read back the existing heading first
2019-11-3
rhoude57 - YUL
gpvillamil Posted at 11-3 12:06
Strange... I ran the exact same program and did not experience the pause after the 2nd turn.
2019-11-3
gpvillamil
rhoude57 - YUL Posted at 11-3 13:22
It’s pretty consistent. I’ve narrowed it down a bit. It pauses for 2 seconds before starting the final straight segment, after making the last turn.
2019-11-4
