This is why I 'need' AEB
12Next >
1713 41 2019-11-3
Montfrooij
Flight distance : 2560453 ft
My most used photo mode with the Mavic Pro is the AEB - 5 option.
It gives you just a bit (a lot) more dynamic range to work with.
Shot taken on the morning after the first frosty night of this year fall season
2019-11-3
DJI Tony
Appreciate sharing this shot with us! Nicely done.
2019-11-3
Woe
Flight distance : 4129268 ft
Sweet shot.
2019-11-3
DJDudu
Flight distance : 102631 ft
Poland
Interesting, at the same time you can feel the freezing cold and the somehow warm sunshine. Keep it up!
2019-11-3
Nebuchadnezzar
Flight distance : 3462946 ft
Good Shot !!
2019-11-3
Montfrooij
DJI Tony Posted at 11-3 15:32
Thanks a lot!
2019-11-3
Montfrooij
Thank you Woe!
2019-11-3
Montfrooij
DJDudu Posted at 11-3 21:48
I surely did not feel that in my fingers
Thanks!
2019-11-3
jacksonnai
Malaysia
Amazing shot! Well done
2019-11-4
Montfrooij
jacksonnai Posted at 11-4 04:41
Thank you!
2019-11-4
Woe
You're welcome
2019-11-4
Flybee
Flight distance : 2203983 ft
Sweden
Exactly my feeling as well, great work Monty
2019-11-4
Montfrooij
Flybee Posted at 11-4 05:55
Thanks a lot!
2019-11-6
jacksonnai
Malaysia
You're welcome Monty!
2019-11-6
ShermanFlyer
Flight distance : 596896 ft
Great shot, looks chilly
2019-11-6
Montfrooij
ShermanFlyer Posted at 11-6 05:45
Thank you!
2019-11-6
Flybee
Sweden
you are most welcome
2019-11-6
ChrisJG
Flight distance : 1725341 ft
Great photo, someone was up bright and early!
2019-11-6
Montfrooij
ChrisJG Posted at 11-6 11:46
Thanks!
Just how I like it
(bright and early)
2019-11-7
DJI Tony
You're most welcome!
2019-11-7
ShermanFlyer
You're welcome
2019-11-12
Montfrooij
Do you use the AEB mode on your MA?
2019-11-12
ShermanFlyer
Montfrooij Posted at 11-12 06:46
Yes I do, probably 95% of the time. gives you so much more flexibility.
2019-11-12
Montfrooij
ShermanFlyer Posted at 11-12 08:39
True.
I'm not able to get so much out of single exposures.
Too much contrast in a lot of situations.
2019-11-12
ShermanFlyer
Montfrooij Posted at 11-12 12:33
True.
Given the time I like to do some comparisons.
e.g. Edit my RAW AEB's individually and then compare them to a stack. Sometimes with interesting results.
That being said, I then spend far too much time deciding which image I like best.
2019-11-12
Montfrooij
ShermanFlyer Posted at 11-12 15:06
Yeah, true.
I know DNG will give you a little bit more headroom .
But not as much as AEB5 does.
By far.
2019-11-12
ShermanFlyer
Montfrooij Posted at 11-12 23:25
Yeah, true.
Question, and I'm picking your brains here
In the live stack TAB, do you have a "Go to Option" e.g. Mean, Medium, etc or is it individual capture dependent. Or do you just create a pixel layer and adjust from there ?
From my perspective it is almost always different .
2019-11-13
Montfrooij
ShermanFlyer Posted at 11-13 14:28
I don't have these options in Affinity Photo.
I assume you are referring to some Adobe product.
But I skipped those some time ago.
2019-11-14
unhommelibre
Flight distance : 109268 ft
Nice shot. I haven't had a chance to try out an AEB shot with my M2P yet.
2019-11-14
Montfrooij
unhommelibre Posted at 11-14 06:07
Thanks!
On the M2P the need is less urgent.
Since you have a larger sensor.
BUT, it will give you a lot more headroom to work with in high contrast situations.
2019-11-14
ShermanFlyer
Montfrooij Posted at 11-14 05:29
I'm referring to Affinity photo, it's all I use. Maybe we are at cross purposes here.
Example from a 5 stack, see layer menu
2019-11-14
Montfrooij
ShermanFlyer Posted at 11-14 14:29
[view_image]
Cool, I never knew that option.
How do you get that?
2019-11-15
ShermanFlyer
Montfrooij Posted at 11-15 01:27
I have used the windows 10 screen recorder to try and demonstrate. Unfortunately it dos not show the pop ups when recording the screen from AP. But hopefully the method should be clear from this short video.
After making your stack, go over to the adjustments section, click on layers, then click on the icon second from right, this will show drop down menu.
2019-11-15
Montfrooij
ShermanFlyer Posted at 11-15 05:38
https://youtu.be/WofoZ9su_Zc
Thanks for that!
I never used live stacks before!
2019-11-15
ShermanFlyer
Montfrooij Posted at 11-15 05:57
Thanks for that!
No problem.
I guess that we use slightly different methods with AEB to produce e.g. a pano
Still, there is more than one way to "Skin a Cat"
2019-11-15
Montfrooij
ShermanFlyer Posted at 11-15 06:29
No problem.
Yeah, I guess so.
What have you done previous to this?
(to get that live stack)
2019-11-15
ShermanFlyer
Montfrooij Posted at 11-15 06:56
Yeah, I guess so.
Sorry, should have said as it's not in the short video.
1. File - New Stack
2. Add AEB files in next menu. No need to check live alignment unless there is motion in the shots
3. Click OK and the stack will be produced allowing access to the live stack menu on the right.
You can then select or deselect any of the AEB files in the stack allowing you to see the difference it makes to the live stack
2019-11-15
Montfrooij
ShermanFlyer Posted at 11-15 07:04
1. File - New Stack
Ah ok.
I always use the HDR merge function.
Super versatile!
2019-11-16
ShermanFlyer
Montfrooij Posted at 11-16 10:51
Ah ok.
Super versatile!
Ok, now that makes sense. We were talking slightly different scenarios. I go the impression your shots had an HDR look to them. But then got a little confused when you talked about stacks in your post, but were not mentioning HDR.
All clear now
2019-11-17
Montfrooij
ShermanFlyer Posted at 11-17 07:23
All clear now
True.
I try not to overdo that effect.
2019-11-17
12Next >
