Canada Mavic Mini in controlled airspace?
12Next >
16589 51 2019-11-4
djiuser_0sznpSoW5hVC
Flight distance : 314820 ft
I'm new to drones and have been looking at the rules in my country for flying (Canada). The Mavic Mini is sub 250g and is classified as a micro-drone so the regulations are limited to "flying responsibly." This makes it a great choice for me except that I live in a control zone. It's class C airspace and I want to fly about 5 km from the center of the control zone in a small park near my house. Would the Mavic mini be able to takeoff here? Or would DJI's geofencing prevent it from takeoff?
Any insight would be appreciated. (I previously posted accidentally in the mavic forum but couldn't find a way to remove my thread)
2019-11-4
DJI Paladin
Flight distance : 318 ft
Hi and welcome to DJI Forum. Thank you for choosing DJI and thank you for the inquiry. In compliance with the relevant laws, policies, and regulations for Canada, some GEO Zones will not appear on this web map. Please refer to the DJI GO app for more GEO Zones in effect. As it consumes too much time for mass data uploading, all safe-fly zones may be hidden when zoomed out. For additional reference I will post a link where in you can check the DJI Flysafe Geo Zone Map ( https://www.dji.com/flysafe/geo-map ). Thank you.
2019-11-4
Thank you so much. It seems like it's an altitude zone with a height limitation so I should be able to takeoff. Thanks for the fast reply!
2019-11-4
ssylca44
Flight distance : 434721 ft
No the Mini is still affected by NFZ
2019-11-4
DJI Paladin
djiuser_0sznpSoW5hVC Posted at 11-4 13:16
Hi we do appreciate your response. If you have any other inquiries or concerns with DJI. Please feel free to reach us at DJI Forum. We are all here to help and support you. Thank you.
2019-11-4
simplesimon
Flight distance : 142841 ft
ssylca44 Posted at 11-4 13:23
I have pretty much the same question as the OP.
I live within the restricted area of an airport on a 3 acre lot, and would like to get a mini to fly it over the trees on my property just for fun.  The Canadian regulations for under 250 grams are kind of vague, and could be reasonably interpreted to mean that anything goes with that size of drone.
My property does show up in a geofenced area on the DJI map, so I assume I would need to send some kind of proof about having permission to unlock the drone to DJI.
Does anyone know definitively if the Mini is exempt from restricted airspace regulations in Canada, and if so, how do I get the drone unlocked?
If I have to go through all kinds of hoops with Nav Canada to try to get permission, I won't be buying a drone.
2019-11-4
ssylca44
simplesimon Posted at 11-4 13:35
Hi, I also live near a small airport and inside a NFZ. I have a Spark since July 2018 and I am able to fly it in my backyard after getting a small unlocked zone around my house. Contact DJI Fly safe for this. The Mavic Mini using GPS will likely be under DJI's NFZ control. Cheers for Kingston.
2019-11-4
SeanGalbraith
Flight distance : 891404 ft
It appears that DJI's NFZ implementation will be stricter than Transport Canada's requirements for sub250 drones.
2019-11-4
simplesimon
ssylca44 Posted at 11-4 14:40
Interesting!
So I suppose it would be possible to make this inquiry before making the purchase?
2019-11-4
Is your NFZ class C airspace?
2019-11-4
simplesimon
djiuser_0sznpSoW5hVC Posted at 11-4 16:25
It's class E.  Not a busy airport.
2019-11-4
ssylca44
simplesimon Posted at 11-4 15:44
Interesting!
You would need the Serial Number of the remote to get the authorization. Cheers
2019-11-5
USS Pretty-Bird (NCC-1702)
Flight distance : 872572 ft
Sub 250g drones in Canada are NOT subject to any of the regulations that pertain to drones over 250g since Transport Canada only has jurisdiction to regulate "Aircraft" which it has defined in the Regulation (same with the FAA rules).  TC has defined these aircraft to be limited to 250g and over.  Unfortunately (?) Geofencing may still prohibit flight within controlled airspace.
2019-11-6
fans683f78b4
Try this from the transport Canada website . Prolly the most accurate to get right from the source .
https://nrc.canada.ca/en/drone-tool/
2019-12-4
fans683f78b4
Will help
2019-12-4
fans683f78b4
DJI Paladin Posted at 11-4 12:55
This works well
2019-12-4
LTE-49
USS Pretty-Bird (NCC-1702) Posted at 11-6 15:18
I wonder if municipal regulations around drones are also based on the Transport Canada definitions.
If a park has "no drone" signs I'd be interested if that refers to drone as defined by transport Canada.
2019-12-5
6arret
Your not allowed to fly in Class C airspace unless your have an advanced operator certificate and an SFOC. Even if your drone is under 250 grams you still have to follow Part IX - Remotely Piloted Aircraft Systems.  https://www.tc.gc.ca/en/services/aviation/drone-safety/flying-drone-safely-legally.html
While flying
To keep yourself and others safe, fly your drone:
  • where you can see it at all times
  • below 122 metres (400 feet) in the air
  • away from bystanders, at a minimum horizontal distance of 30 metres for basic operations
  • away from emergency operations and advertised events
    • Avoid forest fires, outdoor concerts and parades
  • away from airports and heliports
    • 5.6 kilometres (3 nautical miles) from airports
    • 1.9 kilometres (1 nautical mile) from heliports
  • outside controlled airspace (for basic operations only)
  • far away from other aircraft
    • Don’t fly anywhere near airplanes, helicopters and other drones
2019-12-5
6arret
I would not be flying in Class C airspace. You have IFR and VFR traffic in and out of the airport and Class C tends to be pretty busy airspace. Depending where your park is it could right under an approach or take off zone where you have aircraft flying at low altitudes.
2019-12-5
Prairie Chicken
Flight distance : 106526 ft
LTE-49 Posted at 12-5 08:37
In Saskatoon, a local bylaw prohibits drones in public parks. You can observe all the federal regulations, like keeping the correct distance away from people and roads, but if you're in a public park, it's still illegal. And there are no signs posted.
2019-12-5
LTE-49
Prairie Chicken Posted at 12-5 10:06
My question is:  What definition of "Drone" are they using in that municipal bylaw?
2019-12-5
6arret Posted at 12-5 08:55
While flyingTo keep yourself and others safe, fly your drone:
  • This is a pretty old thread and I didn't expect to get response anymore haha. Nevertheless, I've had the mini for awhile now and I after emailing transport canada, we ARE allowed to fly in class C airspace.
    2019-12-5
    6arret
    djiuser_0sznpSoW5hVC Posted at 12-5 12:28
    Can you post the reply from transport? I'm curious to what they said.
    2019-12-6
    6arret Posted at 12-6 06:56
    Of course! I included 2 images. The first was from their general inquires office who gave me conflicting info on whether we should maintain VLOS (we don't for the mavic mini). The second was direct from a civil aviation safety inspector at the RPAS division of Transport Canada (this is the one I print out and bring with me in case). I also carry with me emails from my local police department, bylaw office, and a copy of the transport canada aeronautics law (highlighted with contact info, definitions etc). You don't have to do that, I'm just nuts. Figured it couldn't hurt. At least for me, when I talked with police, they didn't really know the laws and the site they had up was outdated. But again, I printed out all that stuff just in case haha. Everyone who sees me flying a drone are more interested than anything, which is always nice!
    Basically, UAVs under 250 g in Canada are largely unregulated aside from "use common sense" laws. We still have to follow provincial/municipal laws if applicable. For me, Class C airspace covers like 95% of my city so the mavic mini was an instant buy for me.
    ***i have no idea what happened with the formatting of the pictures. it shows duplicates, sorry!! Maybe a moderator could remove the duplicates.***
    2019-12-6
    Prairie Chicken
    LTE-49 Posted at 12-5 10:26
    That's a good question. The city's website just says that all federal regulations apply, plus flying in public spaces is prohibited. It doesn't say if that also applies to sub-250 gram drones like the Mini.
    2019-12-6
    LTE-49
    Prairie Chicken Posted at 12-6 19:18
    That's the thing, the feds have categorized "Drone" as anything over 250 g and "Micro drones" as anything under 250 g.  So if the municipals and provincial laws don't specifically mention Micro Drones then they should need to have a different definition in those bylaws.
    2019-12-6
    Prairie Chicken
    LTE-49 Posted at 12-6 20:09
    Yes, good point. Getting clarification from the local authorities would be a good idea.
    2019-12-7
    skywriter
    Transport Canada has publicly confirmed that restriction on where you can fly do not apply to drones weighing less than 250g (link below).
    Part IX of the Canadian Aviation Regulations applies to all Remote Piloted Aircraft Systems, but subparts 1 & 3 - which include all the regs involving registration, hard limits on where you can fly, pilot certificate testing & special flight operations certificates - only apply to RPA systems that include an aircraft with "a maximum take-off weight of at least 250 g (0.55 pounds)."
    To be specific:
    Subpart 1 "applies in respect of the operation of remotely piloted aircraft systems that include small remotely piloted aircraft" where the definition of "small remotely piloted aircraft" is given as "a remotely piloted aircraft that has a maximum take-off weight of at least 250 g (0.55 pounds) but not more than 25 kg (55 pounds)." The word "include" trips some people up here - as if it might "include" aircraft of at least 250g, but maybe others also. Actually, this really just means if your remotely piloted aircraft SYSTEM includes an AIRCRAFT in that weight range (there's a distinction between the system & the aircraft, for instance, so your remote control doesn't towards the weight).
    Subpart 3, prohibits "operations using a remotely piloted aircraft system that includes a remotely piloted aircraft having a maximum take-off weight of 250 g (0.55 pounds) or more" unless you have a "special flight operations certificate" (SFOC), but this subpart puts no limits on drones under 250g. Of course, flying with an aircraft over 25kg is one of the operation types that requires as SFOC, so that's why this subpart is phrased differently.
    Here's the link to Transport Canada's confirmation:
    twitter (dot) com/Transport_gc/status/1197862816159617024
    2019-12-8
    LTE-49
    I checked some municipalities around me and can confirm that in the bylaws affecting drones they do actually have different definitions.  One near me bans any "Any Motorized flying apparatus" from public parks.
    2019-12-9
    Madperk
    Flight distance : 650089 ft
    Ok I guess I'm a little grumpy but here goes.
    The weight of the drone determines if it needs to be registered and if you need to have a license/certification to fly. Just because it is less than 250 grams does not mean you don’t need to be responsible. Irresponsible behavior by the minority is what caused the majority to have more stringent regulations pushed on to them.
    A 249 gram drone flying at 3000 ft struck by a small airplane could cause some serious damage to the plane. Most of the drone would shatter around the battery which would make a hole in the skin of the plane
    Anything goes is not a reasonable interpretation of the regulations or flying safely. You are still expected to fly safe and follow regulation.  Not doing so can result in some serious trouble.  Go fly your drone over a police car in traffic and see what happens.  When you get in trouble tell them there wrong be cause a 249g drone means you can do what ever you want.
    2019-12-9
    djiuser_v0mz8MJpszFU
    Flight distance : 24104 ft
    I recently got my Advanced Drone Licence here in Canada.  It's a must if you need to fly a 250g+ drone in controlled airspace, but to fly your drone in that airspace you still need to get approval before your flight.  I recently purchased the Mavic Mini to make things easier.  As long as you don't do anything stupid with it you should be good.  Everyone will do what they want, but I would suggest:
    1.  Don't go over 400 feet AGL
    2.  Don't fly it FPV without a visual observer
    3.  Don't fly it near other aircraft
    4.  Be cautious around people....people love to complain about drones
    5.  Follow the municipal by laws, since they will trump the Part IX in terms of where you can fly your drone.
    Micro-drones definitely seem be a 'gray area', or perhaps misunderstood area, in terms of the regulations.  But if too many people do stupid things with them (drones under 250g), then Transport Canada will definitely change the weight classification to include the Mini in the future I would think.
    Also, with the DJI geofences, the Fly app does not appear to have all the NFZ in there.  Where I live there are hospitals that do not have their aerodrome listed on there....only the airport seems to show up.  So you still need to be mindful of where you fly.  Use the Drone site selection tool from https://nrc.canada.ca/en/drone-tool/ to get a better idea of where the different controlled airspaces actually are.
    Sounds like soon DJI will release a firmware update that allows you to fly the Mini in controlled airspace.  But for now, if you live near an airport, the DJI software locks you out....even though it shouldn't.
    2019-12-19
    Tandemist
    Flight distance : 343084 ft
    The answer to your dilemma lies in the FlySafe section of the DJI.com site under Support, More Services. Scroll down and click on GEO Zone Map.
    2020-1-29
    Tandemist
    Tandemist Posted at 1-29 17:50
    It is important to understand that DNF appears not to be in the FltySafe vocabulary. There are Restricted Zones (good luck flying there), Authorization Zones (easy self-authorization, and uncontrolled spaces (just take off).
    If you turn on the Mini, Connect to the controller and get a red GEO zone warning, do the following:
    Press Go Fly
    Tap the three dots in the top right
    Tap Safety
    Scroll down to Unl;ock GEO Zone
    Follow the instructions, answer the questions, and you will be good to fly.
    2020-1-29
    USS Pretty-Bird NCC-1702
    LTE-49 Posted at 2019-12-5 08:37
    2 things: A: any drone flying in the airspace is under Federal jurisdiction currently; so local regulations are in essence illegal/un-enforceable.
    B: Local regs can require you (the operator) to not be allowed to 'fly in or from a park'.  Therefore although they can't prohibit your drone from being in the AIRSPACE over a park, they CAN prohibit you from standing in the park and operating your drone.  So...you can FLY within and over any park so long as you, the operator are not on park property.  You would have to fly over a park while operating the drone from within private property.  This may be difficult to achieve unless your property is near the park...
    2020-4-10
    LTE-49 Posted at 2019-12-9 12:54
    Federal Law governs ALL Canadian Airspace - even the airspace over parks in every city, every province.
    HOWEVER: Local regs can require you (the operator) to not be allowed to 'fly in or from a park'.  This will be the wording if you find this in any local regulation or bylaw.  Therefore although they can't prohibit your drone from being in the AIRSPACE over a park, they CAN prohibit you from standing in the park and operating your drone.  So...you can FLY within and over any park so long as you, the operator are not on park property.  You would have to fly over a park while operating the drone from within private property.  This may be difficult to achieve unless your property is near the park...
    2020-4-10
    USS Pretty-Bird
    The 'Aeronautics Act' is the legislation which governs all aircraft in Canada - and it must be followed by all provinces (eg. no local bylaw may add to or change it).  Federal trumps Provincial.
    In the Act, under definition of "Canadian Aircraft", the definition states "an aircraft which is registered".  A micro drone under 250g (RPAS) is not registered, therefore is NOT a ' Canadian Aircraft' as defined in the Act.  Therefore while it may be referred to or called an 'aircraft' it is not legally an 'aircraft'.  It is an unregulated (aka not under any law or regulation) aircraft, or whatever you wish to call it.  Certainly any local authority (city) can regulate it - but so long as they don't place any regulations on anything in federal airspace - which is ALL airspace in Canada (local municipalities have zero jurisdiction over any airspace).  They can regulate YOU but not your drone in federal airspace.  You could be cited for causing a 'public nuisance', but this wouldn't be a specific drone violation.
    Local regs can only apply to where you physically are as the operator.  Your drone under 250g can be in the airspace over any park; so long as YOU are not IN the park when operating it. It also cannot take off or land in a park.
    "any motorized flying apparatus"....is HOVERING the same as flying
    2020-4-11
    vaughanweather
    Flight distance : 1775144 ft
    USS Pretty-Bird Posted at 4-11 14:08
    Actually, if you register your Mini it becomes a registered aircraft and thus a RPAS. It’s still governed under the CARs via the Aeronautics Act but it is exempted from the requirements for RPASs over 250g.
    So by-law cannot govern your use of the drone within any airspace that is governed under the aeronautics act. They (municipality) can however bar you from landing/lifting off in a park, or operating your controller from within a park etc etc.
    But legally, a municipality would likely not withstand a court challenge should they attempt to control the airspace within a park unless the Aeronautics act was amended to allow this.
    2020-4-15
    djiuser_LiiHhiUdLuDV
    Flight distance : 84777 ft
    djiuser_v0mz8MJpszFU Posted at 2019-12-19 06:59
    My friend work just beside the Trudeau Airport in St-Laurent City and just to try he start his Mini in the parking of his shop and tried to lift off, then the Mini didn't want to lift and tell him he has not right to fly in this zone!
    2020-4-20
    sushiboy21
    I had to same question question so I followed up with Transport Canada, as their rules on <250g micro drones were difficult to discern.
    2020-6-5
    Daniella3d
    ssylca44 Posted at 2019-11-4 13:23
    Nope, I did fly around my house in a NFZ, all I had was a warning and checked the box and OK, and I was good to fly.
    I live inside an airport perimeter, and in a controlled air space. I don't fly high when in that zone, no higher than 130 feet to 150 feet. No airplane is going to fly that low. That's why I like the Mini so much, I can fly it around my house, take pictures of it and it's all legal.
    All you have to obay is to never put any airplane or people in danger. don't fly over 400 feet, respect the general rules, and common sense.
    2020-6-5
    12Next >
