djiuser_nUcNFeH6rIRG
Bangladesh
Flow meters are advanced measuring instruments which are used to measure linear, non-linear, mass or volumetric flow of gases or liquids. It has its applications in various industries such as power and energy, marine, mining, water management, food and processing, building services, aerospace, agriculture, petrochemicals, pharmaceutical and more.
How to Select an Oil Flow Meter?
The most important criteria you should consider while purchasing a handheld instrument is, your requirement of a particular application. Keep in the overall installation and nature of the fluid process. To make your decision easier, answer the following questions:
What is the viscosity of the liquid?
What is it you want to measure?
Are you looking for rate measurement or totalisation or both?
What is the chemical compatibility of the fluid with the instruments whetted parts?
How clean is the fluid?
What is the size of the pipe?
What kind of reading output you want? Electronic signal or local display?
What is the maximum oil flow rate in the pipeline, the pipeline size and pressure available at the Oil flow instrument point?
Types of Flow Meters:
There are several types of liquid and gas measuring instruments designed for use in variety of industries. While some of the Handheld flow instrument is used both in liquid and gases, others are exclusively designed to measure one specific type of matter. The most widely used type of liquid and gas measuring instruments are:
Variable area flow_meter, also known as 'Rota-meter'
Ultrasonic
Anemometers for air flow measurement
Spring and piston meters
Mass gas flowmeters
Magnetic
Turbine
Paddle wheel sensors
Positive displacement flow-meters
Differential pressure sensor
Vortex flow_meters
How to Buy?
While purchasing a handheld flow instrument, make sure that the instrument has all the important features that you require. Some of the most important features to look for when purchasing an instrument are accuracy, reliability, low pressure drop and positive displacement. Online stores provide crisp and clear descriptions such as type, features, price, size, specifications, etc. This information can be quite helpful in your buying decision. You can also consider buying pulse generator along with the Oil Flow Meter to convert the output into a pulse signal for remote instrumentation and control.
Visit Link: silverinstruments dot com
SILVER AUTOMATION INSTRUMENTS industrial process instrumentations solve varies demanding in Agricultural Irrigation, Industrial Water & Wastewater, Factory Process Control, Oil & Gas, Electric Power Generation.etc, our products can be found in huge installations worldwide and domestic.
