daws901
Flight distance : 564154 ft
Guernsey
I am having issues with the Balance tests on my new Ronin SC. I have run around 3 balance tests at 3 different inclinations between the suggested 15 to 45 degrees. Results were excellent across yaw, pitch and roll.
So I don't understand why the grip starts shaking when at an incline in normal use, or when sometimes you can get excellent results and without changing anything, then receive a test that says things need to be adjusted?!
I need help....
App Version is v1.2.4 and Firmware is 1.2.0.10
Thanks
