Mavic Mini Range in the UK?
4389 10 2019-11-8
djiuser_xWcRQemcvnSX
Flight distance : 1171319 ft
How far will the Mavic Mini fly in the UK? I've seen the following specs:
Max Transmission Distance (unobstructed, free of interference)
Model MR1SS5
5.8 GHz: 4000 m (FCC); 2500 m (SRRC)
Model MR1SD25
2.4 GHz: 2000 m (MIC/CE)
5.8 GHz: 500 m (CE)
What is MIC?
2019-11-8
DAFlys
2000m.  MIC is the Japan version of CE
2019-11-8
A J
Flight distance : 14416132 ft
Up to 2KM - not 100% sure what MIC is but obviously some sort of radio frequency compliance used in certain regions/countries.
2019-11-8
DJI Gamora
Hi, thank you for bringing this query to us. The MIC is a Japan version of CE and it stands for Ministry of Internal Affairs and Communications (MIC). Also, the maximum range of the Mavic Mini would depend on the location where you are flying the drone. Please don't hesitate to reach us if you have any inquiries or concerns. Thank you!
2019-11-8
hawkins2000
Flight distance : 1788104 ft
Dear DJI Support. What is the range of the MM (MR1SD25) flown in the United States? I plan a trip around Christmas.
2019-11-8
louis08
The CE model has the same range wherever it flies, there is no such thing like an FCC mode with power boost.
(Just like it was confirmed by DJI technicians that the FCC version will operate at the same power level everywhere)
2019-11-8
djiuser_X6dETQuqBUib
Hi, I am awaiting my mini to be delivered today. I believe form what i read the CE sold in the uk will only travel 500m not 2000m? Legaly only 500m but would it go 2000m if pushed?
2020-5-6
itchyeyeballs
djiuser_X6dETQuqBUib Posted at 5-6 07:34
In the right place 2km max, near sources of wifi interference like houses 500m or less
2020-5-6
itchyeyeballs
louis08 Posted at 2019-11-8 13:25
There are YouTube videos that seem to directly contradict that.
FCC version power is cut in CE area. CE (5ghz) slight increase in FCC area
2020-5-6
djiuser_83xTI2Wz6gNV
Flight distance : 73517 ft
The other day i managed 2550m with the uk version of the mavic mini. I flew from my field with no WiFi interference and went airplane mode for takeoff until a distance away and then reintroduced 4g to gain the map again. The signal started to break up around this distance so I turned back although I may have been able to get further. I chose a 2.4ghz channel and was very surprised by the results! No range extenders fitted either. (Also aware I got the warning of being in the zone of an airport. It is a small local airfield and the time of my flight was after closing hours of the airfield)
2020-10-26
djiuser_zV5dzj1k1qIn
Flight distance : 11791 ft
Hello, hoping someone can help me on here,
I haven’t used my mavic mini for aprox 6 months,
I have turned it on all the batteries fully charged and connected to the app, I have done all the soft wear updates and it says on the screen ready to fly, but when I pull the triggers nothing happens at all? Any ideas before I send it away for repair?
2022-5-1
