Restricted Zone - Fly Inside?
2188 15 2019-11-8
k_hargy
Flight distance : 51624 ft
I'm thinking about getting a Mavic Mini and I live in a large restrcted zone (Northern VA). The way I understand it the software locks you out from even taking off? What about inside, are you able to fly inside in a restricted zone?
Edit: Just realized my question was worded poorly and unclear... I meant can I fly inside MY HOUSE
2019-11-8
DJI Gamora
Hi, thank you for reaching out. I will highly recommend you to fly in an open area wherein it is not restricted since the restricted zones for the Mavic Mini are the same as that of other consumer aircraft. I will be posting a link wherein you can check your location if that is inside the NO-FLY zone. Thank you for your understanding and support!
https://www.dji.com/flysafe/geo-map
2019-11-8
Ex Machina
Flight distance : 1806362 ft
Wait, I thought the whole point of keeping the Mini under 250 grams was to avoid regulatory restrictions?
2019-11-8
louis08
The weight (or lack thereof) could save you from restrictions like pilot certificate, drone ID, mandatory insurance, etc.
No-fly zones remain no-fly zones, hence the name....
2019-11-8
Ex Machina
louis08 Posted at 11-8 13:22
Are we sure about this? My understanding is zero-regulation means zero-regulation, and RFZ are regulatory instruments.
2019-11-8
Rustic17
Flight distance : 2733760 ft
I don't know where you are getting this "zero-regulation" from...you will still have to abide by the  FAA limits like 400', daylight only, not being a danger to other aircraft, etc.  The less than 250 grams just means you don't have to register it.
2019-11-8
k_hargy
DJI Gamora Posted at 11-8 13:06
Sorry my question was worded poorly... I meant can I fly inside my house!
2019-11-8
KREMi
Poland
in Your house most likely there won't be GPS signal, so drone should not go into restricted mode, as he will not know where it's flying.
some reviews did fly it inside homes, so there should be atti mode possible.
2019-11-9
DJI Gamora
k_hargy Posted at 11-8 19:32
Hi, thank you for the additional information. We do not recommend flying the drone on the location wherein there is no GPS signal since the drone might cause some stability issues. I will highly recommend flying the drone on the location that has a strong GPS signal and away from any possible interference. Thank you for your understanding and support!
2019-11-9
Ex Machina
Rustic17 Posted at 11-8 15:05
Thanks — do you have a link that defines that regulatory restrictions are still in-play for model aircraft under 250g?
2019-11-10
S-e-ven
Flight distance : 5922034 ft
Thailand
Ex Machina Posted at 11-10 17:52
Do you really have the idea that you can't fly a Spark near an Airport but can do so with a Mini?
Or near the POTUS?
Just asking ....
2019-11-10
Rustic17
https://www.faa.gov/uas/recreational_fliers/
2019-11-10
Ex Machina
Thanks again -- I was hoping that would clear things up but I'm still having problems sussing this out to my satisfaction. When I first started researching drone regulations, back before I bought my Mavic Pro, it seemed pretty clear the FAA was only interested in regulating drones over a certain weight, the threshold determined to be 250g. Now, it's not so clear to me.
DJI on why they made a sub-250g drone suggests less governmental restrictions as one of the reasons, but doesn't go into specifics -- which probably vary from locale, anyway.
https://content.dji.com/why-did-dji-create-a-249-gram-drone/
In the US it's clear that registration is unnecessary for drones under 250g, and you could read the law as applying equally to all drones under 55lbs, but I'd be happiest with the FAA declaring definitively whether I can fly my 249g drone in my old backyard in the Washington, DC suburbs like the OP despite being within the 15 mile RFZ. In my mind this is not so different from flying kites on the national mall (which have a 5lbs limit, btw).
I can't imagine required registration being a deal-breaker for anyone, but maybe DJI's market research has found otherwise.
2019-11-12
Ex Machina
S-e-ven Posted at 11-10 18:27
Or near the POTUS?
Just asking ....
At a fraction of the weight of a pigeon, yeah, I think it's probably not something we need to worry about for either AC, but the law says 250g, so Sparks are out. DJI's safety whitepaper argues that 2.2kg is a more reasonable safety limit but here we are.
2019-11-12
Rustic17
Keep in mind, a large percentage of drones fliers are not in the U.S.   The 249 gram drone may well have been designed for drone fliers in other countries, for example Canada, who have a lot fewer restrictions/licensing/registration if their drone is less than 250 grams.
2019-11-12
CaLand
Flight distance : 1336483 ft
recommend LAANC authorization input for take off in areas that require it. if we have requested and received automated authorization to fly the software and aircraft should recognize we do not all have the luxury of living in class"G" airspace
2019-11-12
