S-e-ven
Flight distance : 3740030 ft
Thailand
As soon you have green "stuff" between RC antennas and bird, it is interfering.
The main problem is: You may still see the bird, vlos, but you have the RC 30-40cm more down, so the RC has already the treetop in the "LOS"
If your position is at 1, and you are flying the path 2------>, it really is a question about how high your drone flies and how high the trees are.
Pythagoras gives you an idea:
Distance from 1 to first tree plus height of the tree, that gives you the minimum angle for your bird.
And tells you how high you need to fly, in case you wanna get 200m or 500m behind 2 |
