Not Recognized by DJI Assitant2
708 2 2019-11-10
vipersl65
Flight distance : 31644 ft
I got the regular goggles. I know I activated this already because whenever i turned it on, the activation screen is no longer there.   I downloaded the DJI Assitant 2 FPV series version 2.0 and want to upgrade the firmsware but it is not being recognized by the software.  Pls help.  thanks
2019-11-10
vipersl65
Tried it on Windows 10 and Win 7 but stillnot bring recognized
2019-11-10
DJI Gamora
Hi, thank you for bringing this query to us. We're deeply sorry for the inconvenience that this has caused you. Can you please try to uninstall and reinstall the DJI Assistant 2 software on your PC to see if the problem persists? You may refer to the link below. You can also try to use a different USB communication cable and check if you can now connect your DJI Goggles to your PC. A friendly reminder, please make sure that you are using a data cable for us to make sure that the DJI Goggles will transmit data to the computer since if you are using a charging cable it will not work or either will not transmit data. Please keep us posted. Thank you for your understanding and support!
https://www.dji.com/dji-goggles/info#downloads
2019-11-10
