I got fcc model in Europe
123
19544 119 2019-11-11
CemAygun
Flight distance : 810 ft
Turkey
S-e-ven Posted at 11-12 22:41
Ehm, I am wondering about something.  could be a typo, but could also be the trouble wit FCC drones sold in Ce/Europe?
DJI says, there are 2 models:
Good catch! Never noticed that "R" until you pointed out. Maybe it is a typo as you said?
2019-11-12
S-e-ven
Flight distance : 5922034 ft
Thailand
CemAygun Posted at 11-12 23:00
https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=201204&pid=2000829
Thanks, I missed that one.
2019-11-12
S-e-ven
Thailand
CemAygun Posted at 11-12 23:05
Needs DJI, to clear that up.
So.... we wait! ;-)
2019-11-12
nik1975
Flight distance : 6300833 ft
Switzerland
I think I give it back.....
2019-11-13
hawkins2000
Flight distance : 1788104 ft
"R" means Receiver.... So the aircraft
"T" means Transmitter... So the controller
2019-11-13
Spud211
So I contacted DJI support about this today - this was their response...
Upon checking your concern, please check the serial number of the first three digit is "1T2" for remote controller and "1SZ" then it is FCC version but if the first digit is "1WH" for remote controller and  "1WG" for the aircraft then it is CE version. I hope that answered your concern.
In my case, the serial number on the mini does indeed start "1WG", so this all implies that I do have a CE model and the lack of a 2.4ghz option & the message on connection are both just software issues that should be fixed....the serial that it shown in DJI fly is actually different, but it doesn't start 1SZ so it's probably normal (I assume the stickered serial is the whole unit, and the one the app reports is just the aircraft without gimble etc.
I'll update the thread if I hear back.
Does anyone else reading this thread have a CE version that actually shows up as such when you connect it to your phone?
I did reply back to DJI to ask about this specifically, but unsurprisingly I have not heard back yet
2019-11-13
Spud211
right, so I figured it out
It is a CE model, it's just a firmware bug that shows the wrong ID when you connect.
To swap to 2.4ghz, you  just tap one of the 2 digit channels....i.e. all the red ones if you are indoors ;)  There isn't a switch between 2.4 and 5.8, its been over simplified so you don't notice ;)
Feel a bit silly now, but hey at least mystery solved for me
2019-11-13
nik1975
Switzerland
Spud211 Posted at 11-13 12:15
I have same problem but i must check the  serial  .....
So how did the fix your problem?
Did you sent it back ?
Or did you become some software ?
2019-11-13
nik1975
Switzerland
So my one is sta starting with  1WF the controller and the Mini with 1SCC
What does this mean?
DJI???
2019-11-13
cegio
Flight distance : 671257 ft
Another partner has tried an FCC in Europe and has not been able to pass 500 meters, when in South America in the same circumstances he could reach 1,500 meters (city with large buildings)
2019-11-13
nik1975
Switzerland
Just two peoples with that issues???
2019-11-13
Nebuchadnezzar
Flight distance : 3462946 ft
cegio Posted at 11-13 23:25
es un FCC  europeo , de baja potencia , nada que ver con el modo (FCC) uSA , SOLO HAY QUE VER LA BANDA DE 2,4 gHZ para saber si estas en CE ó FCC , si aparecen 13 canales en la banda de 2,4 gHZ estarias en CE , en cambio si hay 11 , estarias en FCC , yo lo checkeo así en mi Phantom 3 SE y Mavic Pro,
La diferencia es brutal , con pahtom 3 se no alcanzaba mas de 700 ,con un monton de problemas de perdida de señal ... en FCC (11 canales) me llevo el dron hasta que pierde la señal y  vuelve solo a casa, unos 5 Kilometros , Salu2
2019-11-13
petek9
nik1975 Posted at 11-13 23:03
DJI???
When you say your mini serial starts wth 1SCC - are you reading that number from the app or from the little sticker inside the battery cover?
The one the app reports is wrong (for this purpose)..definitely check the sticker on the mini itself.
I didnt do anything to fix it - it was never broken, its just the firmware identifies the mini as the FCC even though its really a CE.
Go to your radio tab in DJI Fly,change channel mode to Manual and then tap on any of the 2 digit channels e.g. 09 (its likely a big red one...) and you will then see the band switch to 2.4ghz
2019-11-14
CemAygun
Turkey
hawkins2000 Posted at 11-13 08:43
Ah I see, thank you!
2019-11-14
nik1975
Switzerland
petek9 Posted at 11-14 00:44
It's  serial number of the app  not on the  drone inside....
Outside of the controller it's  start WH
2019-11-14
Spud211
nik1975 Posted at 11-14 01:28
That means you have a CE model.  Try clicking on one of the single or two digit channels....it should work
2019-11-14
Juliflash
Flight distance : 2923 ft
Nebuchadnezzar Posted at 11-13 23:48
Hola Nebuchadnezzar, a que te refieres con "es un FCC  europeo , de baja potencia,"?
Si compras un modelo FCC para usar en Europa, viene capado pues y ser'ia mejor la versión CE?
2019-11-14
Nebuchadnezzar
Juliflash Posted at 11-14 02:25
eso es lo que se debate , y esperando pruebas , ya veremos que version alcanza mas , yo creo que la Fcc alcanzará más , aunque te enfrentas a temas legales usando esa potencia aqui ......
2019-11-14
Juliflash
Nebuchadnezzar Posted at 11-14 02:30
Ya, comprendo.
Se me escapa un poco el tema de las diferentes frecuencias aunque mas o menos comprendo que es un tema legal, de señales con menor potencia y de ahi el menor rango.
Lo que pensaba la señal en Europa era de menor rango pero mayor potencia.
2019-11-14
Nebuchadnezzar
Juliflash Posted at 11-14 02:35
Ya, comprendo.
Ahi tienes para que lo entiendas mejor
2019-11-14
Nebuchadnezzar
Ya, comprendo.
Como podras observar, la potencia en CE  , ES UNA PU...  mierda hablando en plata y pronto
2019-11-14
Juliflash
Nebuchadnezzar Posted at 11-14 02:40
[view_image]
Wow eso clarifica mucho la verdad. Gracias!
Y esos son los valores legales? o los podrán incrementar mediante software?
Si decian que llega a 2Km en europa, debería ser así no?
2019-11-14
Nebuchadnezzar
Juliflash Posted at 11-14 03:00
Antes se podia via software , en este caso no se podrá
2019-11-14
Nebuchadnezzar
hay que esperar test por parte de europeos que nos digan que ocurre en cada version
2019-11-14
Juliflash
Nebuchadnezzar Posted at 11-14 03:18
Perfecto grtacias por la info!
2019-11-14
S-e-ven
Thailand
Of course, the app  connects to the RC, not to the bird.
But: Could be mentioned, somewhere, right?
2019-11-14
Christian U
Flight distance : 189659 ft
The Channel display looks same for me.
But in the USB Connection Dialog no Model number is shown for me.
My Serials are both for CE Version.
Also i have not the feeling that the Output power is 1W ! I get signal problems when i fly 150m side of me and there are some trees between the drone and me (i see it anyway )
2019-11-26
JodyB
Flight distance : 302536 ft
S-e-ven Posted at 11-11 07:20
Switzerland isn't part of the EU, isn't it?
Perhaps that is, why nik1975 got a FCC Mavic Mini?
From what I understand, Switzerland formerly withdrew their application to join teh European Union in 2016. If that holds true, then anyone ordering a drone living in Switzerland should get the FCC version. I could be wrong though, but seems that is what I remember anyway.
2019-11-26
cegio
Se puede poner en fcc el CE del mini , pero en 2.4 apenas tienen beneficio, el 5.8 si que gana practicamente el doble de alcance.
2019-11-27
Nebuchadnezzar
cegio Posted at 11-27 15:00
yo de momento no me interesa el alcanze ... este dron es muy muy versatil en cortas distancias Salu2
Nunca antes habia filmado asi :
2019-11-27
Nebuchadnezzar
2019-11-27
Nebuchadnezzar
Puedo asegurar algo , mi prespectiva de uso ha cambiado radical desde hace una semana que uso esta maravilla ....
2019-11-27
Nebuchadnezzar
Antes solo salia al campo a hacer vuelos  (por respetar las leyes)  , ahora puedo en campo cecano jejej
2019-11-27
Luciano Couto
Brazil
Could you please post some pictures of the Mavic Mini and the controller showing their labels? No need to show the serial number, just the CE and/or FCC and the model number. This will help a lot!
2019-11-28
InspektorGadjet
Flight distance : 439915 ft
Nebuchadnezzar Posted at 11-27 23:11
Sin duda muy comodo por su tamaño tambien.
2019-11-28
fans93f430d5
nik1975 Posted at 2019-11-12 01:20
The problem is that you have in Europe the 5.8 ce signal and not the 5.8 fcc signal..... that's the point.
So every one who like to buy some drone from US or anything else outside of EU you got the same problem..... so don't do it..... it doesn't work
Not a problem according to the new gps trick that seems to unlock the full 1mw (4km) range, which would allow not only for longer distances but hopefully more stable connections.
Have you tried this?
Everyone is waiting to see if we can possible unlock a CE remote to FCC, thus if the gps trick is working for you it would be proof that FCC firmware could possibly work on a CE remote and unlock full power via the trick.
Please please kindly try it out. So many people probably contemplating on purchasing a CE drone for that reason.
2020-1-2
markusd1984
fans93f430d5 Posted at 1-2 02:13
https://www.youtube.com/watch?v=6LE461SFRZ8Have you tried this?
I only saw the post now about the difference in MM motherboard difference in MM motherboard, thus it confirmed it's not just a matter of the remote's firmware and therefore due to the lack of hardware in the CE drone's motherboard it won't be possible
https://forum.dji.com/thread-202990-1-1.html
2020-1-13
Giacob
Hi all, I have a "1T2" MR1SS5 FCC model, but I don't have channel 165 in the list. Do you have an idea why?
2020-9-22
Andy Uk
Flight distance : 3985676 ft
This is showing the 2.4ghz channels.  The FCC Model doesn't support 2.4 on 5.8.
2020-9-22
amir_KING
Flight distance : 372992 ft
nik1975 Posted at 2019-11-11 05:32
No worries Mindy,
I dont like to change it .... its ok for me.
2020-9-22
123
