Get the best out of your OSMO Pocket
12Next >
13751 66 2019-11-11
Madebyvadim
Flight distance : 2023002 ft
Russia
Let’s face it we all like this little machine. It is small and compact, its shoot 4k, it has a handful of cool features, but not everyone is convinced it can produce great results.
So how do we squeeze the best out of it?
Let me tell you a few things that will help you to get the best out of your Osmo Pocket.
Accessories
There are tons of great accessories available for OP out there, but perhaps the most important is ND filters. So why is that? Ok we all strive for better video/films, we want it to be more cinematic and movie-like instead of just a video, and what’s better than a good ol’ motion blur? That’s will make your footage looks more professional and pleasing to viewers. And how to achieve that if you shoot at a bright light? Right ... Exactly ... ND filters. And since they are so easy to take on and of due to the magic of magnetism, there is no brainer. Get yourself a few ND (from ND 4 - ND 32) and you will be good to go. I use Polar Pro set.
Another great addition is cases with a thread so you can put OP on a tripod (Great for timelapses or motionlapses)
A small tripod is also a cool addition. You can have even more stable motionlapse or even pan/tilt videos.
Another one of my favorites is a Wifi module. First, it works as a more stable stand on its own. Second, you can put OP to some places where you can not see the screen properly nor can attach the phone, but you can use it with wifi.
Also if you shoot with someone you can use it as a director’s monitor.
A great addition to the collection of accessories will be a monopod preferably with an extended pole. You can use it in various creatives ways including this [link]
Handling
Because OP is a lightweight device (which is great) it has a downfall. It shakes easier than heavier stabilizer systems. So be very careful and walk smoother and try not to make amplitude movements (up/down) as they are almost impossible to get rid of on the post-production stage. Take your time and make a few runs.
You can buy an accessory such as this to help a little bit with handles but still all depends on your ability to walk like a ninja
You can also use an electric scooter for super smooth shots or long hyper-lapses.
Creative movements
After you succeed with traditional types of movements its time to try something new. Roll, fly through or boom imitation is just a few techniques to try out. Check this great video to start your creative juice flowing.
A tip from me. You can use the on-screen joystick to operate your camera, however, I find it quite difficult to have slow and steady movements and there are no settings to adjust. So to cheat it a bit I usually select a non-moving object for tracking and then use onscreen controls and in that case, the movement of the camera will be a bit limited on degrees, but it will move much slower and smoother.
I really like the motionlapse feature. And if you use ND filters you can have a long exposure motion and timelapses which looks great.
Since I like my shots to have slow and steady motion I usually use either lock or track motion mode. I find fav a bit hectic to control. But if you are like visually more fast motion shots, then fpv is one to consider.
I like the hyperlapse feature but I prefer to have more control with my shots hence I shoot normally and then retime video in post-processing. Start at 1000% and adjust to your liking. In this case, you can have full control over the retiming of your hyperlapses.
Video settings
Let's talk about the right settings.
I shoot all my base footage at 24fps (23.976 to be correct)
I use both jpegs and video for timepalses and motionlapses, in my opinion, you can get more out jpegs sequences in post-processing using Lightroom and LRTimelapse then if you use only the video.
I use ND filters to reduce the light coming to the lens to achieve 180° rules for great motion blur (double your fps by 2 to get a correct exposure, for example, 24x2=48 so closest shutter speed is 50 so use 1/50 for great motion blur)
Stay at lower ISO possible to avoid noise. I usually shoot with ISO 100, but at the darker time I had to switch to higher ISO 400-800 for that I have to compensate with reducing noise in post-processing. In my opinion, anything above 800 is way too noisy so try to stay out of it.
I use manual exposure in many cases so I have a better control over the picture. ( sometimes I underexpose shots so I can still have good highlights and be able to recover shadows)
4k is my setting to shoot video, however, I not creating final videos in 4k. I output in 3k so in that case, I have more control over composition. I can even zoom in/out a bit or pan shots.
My personal preferences are to create images in 2.39:1 aspect ration. This aspect ratio is for anamorphic and looks really great to the eye.
Post-production
I use Davinci Resolve 16 for all my video editing, grading, sfx, sky replacements and so on, except titles (I find it easier to create in Adobe After Effects)
For me, post-production is a vital part of film creation. I carefully choose my main soundtrack so it is not just “because I find free stuff on some stock music site” but since I strive to create memorable films, it’s rather very important that it reflects mood and feel of the film to its highest. Sometimes it takes me 1-2 weeks to find the right candidate for my score.
SFX is also an important part of any production. It will bring more atmosphere to the film and made it look more polished and professional.
Color correction and grading is that part where you can set a strong tone for your production. Choose carefully the grading for your film. It should reflect the idea of the video as well as mood.
Bad or inappropriate grading can ruin the feel of the whole film.
Editing is another very important part. Choose only the best cuts, carefully edit your shots. It is better to leave your film for 1-2 days, after all, is done and to come back with “a pair of fresh eyes” or better yet make a small screening for close friends or colleagues and see their reactions, listen to their feedback and see if the film needs adjustments.
It will be a bonus if you could create a strong, memorable poster for your film.
It will grab the attention to it right away. Don’t make cliche YT type covers, instead aim for more of a movie like a poster type.
Create both horizontal and vertical versions for different social platform type.
You could create a poster from your video as a screenshot but better yet is to shoot a raw photo with OP on location if you feel like the scene could become your poster frame. In that case, you have a bit more room to adjust it in post.
I hope this post will be helpful to you.
Good luck with your creations.
2019-11-11
KostaN
Yes very useful tips.
2019-11-11
Madebyvadim
Russia
KostaN Posted at 11-11 21:02
Thank you
2019-11-11
Montfrooij
Flight distance : 2560453 ft
Very impressive work!
2019-11-12
DJI Tony
We highly appreciate sharing this informative thread to our valued DJI Forum members. Nice work!
2019-11-12
Madebyvadim
Russia
Montfrooij Posted at 11-12 06:30
Thank you.!
2019-11-13
Madebyvadim
Russia
DJI Tony Posted at 11-12 09:57
Thanks a lot Tony!
2019-11-13
RjSona
Thanks for sharing useful tips
2019-11-13
Montfrooij
You're welcome!
2019-11-13
Madebyvadim
Russia
RjSona Posted at 11-13 02:49
My pleasure
2019-11-13
jacksonnai
Malaysia
Great thread, very useful information and tips! Thanks for sharing
2019-11-14
Madebyvadim
Russia
jacksonnai Posted at 11-14 04:23
Awesome. You are welcome.
2019-11-14
jacksonnai
Malaysia
Madebyvadim Posted at 11-14 05:48
No problem Madebyvadim!
2019-11-16
Zubayer.Khan
Flight distance : 766421 ft
Bangladesh
very useful tips
2019-11-18
Madebyvadim
Zubayer.Khan Posted at 11-18 09:09
very useful tips
Thank you ! Enjoy
2019-11-21
pianoplayer7
Flight distance : 259055 ft
Great shots and amazing tips. I have ordered an Osmo Pocket and hope for it to come soon. I will definitely be referencing this thread when I receive it.
2019-11-25
prodocuments
We are a group of professionals with many years of experience in
Manufacture of original and forged passports and other identity documents, the best
Producers of high quality counterfeit documents.
WEBSITE: https://prodocuments.cc
Circulating documents in the world. We only offer original high
Qualities of real fake passport, driver’s license, badges, stamps,,
Birth certificates, international fake diplomas and other products for
A number of countries such as: USA, Australia, Belgium, Brazil, Norway
Canada, Italy, Finland, France, Germany, Israel, Mexico, Netherlands,
South Africa, Spain, Great Britain. etc
This list is incomplete.
For more information and ordering contact us via email or phone or skype
Whatsapp number …………………… ……. +1 (661) 473-0239
General support: ………… ……………… remyarnolds@gmail.com
Contact e-mails: … ……………….. … ..prodocuments88@outlook.com
Feel free to contact us anytime and in any discretion.
Keywords:
Buy registered and unregistered ID cards
Buy registered and unregistered driver’s license worldwide
Buy registered and unregistered USA (USA) passports,
Buy registered and unregistered Australian passports,
Buy registered and unregistered Belgium passports,
Buy registered and unregistered Brazilian (Brazil) passports,
Buy registeAred and unregistered Canadian (Canada) passports,
Buy registered and unregistered Finnish (Finland) passports,
Buy registered and unregistered French (France) passports,
Buy registered and unregistered German (Germany) passports,
Buy registered and unregistered Dutch (Holland / Netherlands) passports,
Buy registered and unregistered Israel passports,
Buy registered and unregistered UK (United Kingdom) passports,
Buy registered and unregistered Spanish (Spain) passports,
Buy registered and unregistered Mexican (Mexico) passports,
Buy registered and unregistered South African Passports.
Buy registered and unregistered Australian driving licenses,
Buy registered and unregistered Canadian driver’s licenses,
Buy registered and unregistered Dutch (Holland / Netherlands) driving licenses,
Buy registered and unregistered German (Germany) driving licenses,
Buy registered and unregistered UK (United Kingdom) driving licenses,
Buy registered and unregistered Diplomatic Passports,
ielts certificates for sale
birth certificates for sale
us passports for sale
legit passports for sale
fake passports for sale
uk drivers license for sale
uk permit for sale
Spanish passports for sale
new York drivers license for sale
Best quality passports
Schenghen visas for sale
New York ID card for sale
Fake id cards for sale
Novelty passports
Genuine passports
Citizenship documents for sale
Fake drivers license
Diplomas for sale
Credit cards details for sale
Stolen passports for sale
Resident permit card for sale
Diplomatic passports for sale
TOEFL certificates for sale
Real passports for sale
Buy fake passport British(UK) for sale
Diplomatic Canadian false ID card
WhatsApp +1 (661) 473-0239 YOU CAN NOW OBTAIN YOUR #IELTS CERTIFICATE. WE CAN GET YOU REGISTERED AND OBTAIN YOU A VALID IELTS CERTIFICATE WITH ONLINE VERIFICATION POSSIBILITIES. THE CERTIFICATE CAN BE USED FOR ALL STUDY IMMIGRATION PURPOSES IN ANY COUNTRY WEBSITE: https://prodocuments.cc *We are a team of certified and registered #Immigration experts, who have been with #immigration* *process for over 12 years. Our several clients have gotten* #Studentvisa #Touristvisa #PR WEBSITE: https://prodocuments.cc
2019-11-26
prodocuments
Keywords:
uk permit for sale
Novelty passports
Genuine passports
Diplomas for sale
2019-11-26
David J.
Flight distance : 1231385 ft
If I had to go either with ND or ND/Pl filters, which would you recommend?
2019-11-26
Madebyvadim
David J. Posted at 11-26 19:20
I personally use ND only because I don’t shoot water stuff Or reflections so much. I find it cumbersome to fiddle with PL filters.
2019-11-27
Madebyvadim
pianoplayer7 Posted at 11-25 07:18
Awesome. Enjoy !
2019-11-27
Trikke
Flight distance : 2311955 ft
Belgium
thnx for the extra info. great explication you did here
2019-11-27
Madebyvadim
Russia
Trikke Posted at 11-27 03:31
My pleasure. Enjoy !
2019-11-27
Olman Chacon
Costa Rica
Thanks for Your Tips.
2019-11-29
Madebyvadim
Russia
You are welcome!
2019-11-29
InspektorGadjet
Flight distance : 439915 ft
Very useful and nice shots!
2019-12-1
pinkmenprints
Singapore
Nice poster for video front page
2019-12-1
Madebyvadim
Russia
pinkmenprints Posted at 12-1 21:16
Cheers mate !
2019-12-1
Mountaindrone-Dronefocus
Flight distance : 26618251 ft
Thanks you very much for this tips !
2019-12-2
Zubayer.Khan
Bangladesh
you are wellcome
2019-12-2
Barty
South Africa
I know I am so late to the party, but my P3P is giving me the ESC Error on FW 1.11.20. Does anyone have a copy of 1.11.30 to send me so that I can update?
Thank you.
2019-12-2
Jkzcdfkj
Switzerland
"So to cheat it a bit I usually select a non-moving object for tracking and then use onscreen controls"
I don't understand your technique here. If you track a non-moving object, I don't get how your frame is not going to stay static on the non-moving object.
So what onscreen controls do you mean ?
2019-12-2
Madebyvadim
Russia
Jkzcdfkj Posted at 12-2 12:56
To understand what I mean try to pan or tilt or both using onscreen joystick in order to make smooth and really slow movements of the stationary camera, then you will see. It’s quite difficult because the movement is quite quick and could not be slow down in any settings.
Now swipe around the static object and track it AND now use onscreen joystick. You will see that movement is super slow and smooth.
This is a technique for slow pan/tilt/move lens on a steady shot. Not so much useful in actual DOP movements.
I hope it clarified it more.
2019-12-2
djiuser_PLcqRY0lk2RF
Will the mavic mini FCC version work in the Philippines? I haven't found any definitive info whether the drone can auto switch mode based on location or if it will be travel friendly in south east asia.  Thanks
2019-12-2
Isilosc
Flight distance : 338186 ft
Dominican Republic
Thank you
2019-12-3
Madebyvadim
Russia
Welcome !!
2019-12-3
Lysak2003
Flight distance : 500052 ft
Ukraine
Thank you for the useful tips and tricks! I assume this article as the best starting point for OP beginners as I am and really enjoy to read it and learn. BTW, in "Creative Movements" section you've mentioned "Check this great video to start your creative juice flowing", but there is no link in the text. Is there something you could miss?
2019-12-3
Madebyvadim
Russia
Lysak2003 Posted at 12-3 06:27
You are most welcome! Indeed I article missing the link -
2019-12-3
vividdreamsphot
beauty! we use it at https://vividdreams.ca
2019-12-3
fans69b0dd21
That was awesome . . . .what a wonderful talent you have.
2019-12-3
12Next >
