crash my mavic pro, have insurence on it, But mavic pro is out from best buy, and Best Buy only has Mavic pro Platinum fly more combo and is willing to give me my replacement But the Mavic pro Platinum fly more combo and they will take off another $100
so I still have 2 battery's to my mavic pro, can those battery be use in mavic pro platinum drone?
one battery does 27 or 28 mins platinum does 30 mins.
Hi, I am sorry to know that your Mavic Pro had crashed, regarding the Mavic Pro Platinum, the battery is compatible. For more details I have posted a link for the DJI Mavic Pro Platinum ( https://www.dji.com/mavic-pro-platinum/info#faq ). Thank you for your valued support.
since i had a Mavic Pro already, does this stay the same? or will this icon change to mavic pro platinum? how do You add or remove it?
and will this link up to my already flight record and distance i have flown already? or will this info start all over when i link this mavic to my cellphone?
D-Rosin Posted at 11-11 18:13
and will this link up to my already flight record and distance i have flown already? or will this info start all over when i link this mavic to my cellphone? [view_image]
A platinum image will appear along side your current drone when you activate the drone as long as its brand new.
DAFlys Posted at 11-11 23:36
And will my flight record & distance and etc still be the same account? or will this start a fresh new flight record?
I still have not set up nothing yet so still in the box, But when i do will i need a new FFA drone number? when i sign up? or can i use my same sticker from my old drone?
D-Rosin Posted at 11-12 16:45
You get another tab in the app so you'll have a personal flight log, then a tab for each drone.
The flight record and distance will be added to your DJI account - once you've registered the new drone with DJI.
Lamplighter55 Posted at 11-13 01:41
OK so then this will give me 2 flight account records then? since i got a new drone cause i crash the first one? cause i already have my crash account record. or will i be able to remove the first account flight record?
D-Rosin Posted at 11-13 07:11
As you should be able to see - on this forum your account is now showing a second drone associated with your DJI account. On your phone/tablet the DJI GO 4 app you will see the two drones as separate devices - each with their own flight records. On your account both devices' flight distances are added - so you'll get the sum of all flight distances showing under your overall profile (and also on this forum/platform, after you sync your flight records from within the GO 4 app, when you have a live internet connection).
They are ghosts/avatars but do respond if you post a question - often with a fairly standard reply if the question is a common one - like "My drone crashed, why?!" etc. Usually if its a hardware/software failure the question will get elevated to a support ticket - and you'll be DM'd on the matter.
