Activation Failed (Failed to verify SN. Resstar DJI GO)
1632 4 2019-11-13
ypsdario
Flight distance : 37480 ft
Colombia
Hello!
I had to change the Wi-Fi module and the main board,
which I bought through Amazon,
turned on my osmo + connected to my phone and then
updated to the latest version, at the end I was asked to
"Activate" my device, but when trying Doing so throws me the
following error
Activation Failed (Failed to verify SN. Restate DJI GO).
Contact DJI support if the problem persists after restart
My DJI account is:
yepitos329@gmail.com
Thank you!
2019-11-13
fans6426ccaa
Did anyone ever get back to you about this? I’ve been getting the same error trying to activate my new drone for months
2019-11-29
ypsdario
Colombia
fans6426ccaa Posted at 11-29 23:59
they insist that I must send my osmo to their facilities so they can check it
2019-12-3
djiuser_ZkzkRrmEa8vR
Mine is doing the same thing, is there any fix yet?
2020-7-15
geroallue
Flight distance : 30085 ft
Argentina
that problem comes when you swap main board or lens module.
the drone or osmo came paired
the mainboard and lens module have to be the same always, you can replace everything, but when you dismatch this parts, it appears the activation error,
for example if you buy a drone and put a brand new gimbal because you crashed, you have to put off the camera and put in the new gimbal, the problem its solved,
if not, another alternative its to use LITCHI app, no more DJI app problems! haha
2022-6-22
