fans3dc89abd
SOLVED for ground stations!
I am using a triversity TriplePlay ground station which has a Video out cable with a yellow RCA video connector. Using a 3.5mm to RCA cable (link below) but connecting the yellow video RCA connector from the ground station to the red (audio right) RCA connector on the cable provided the correct video connection to the DJI FPV V2 goggles. The fit to the goggles was tight since the plastic around the 3.5mm plug is large diameter. I shaved the plastic down with a pocket knife to make it go in easier. I am still debating about cutting off the 2 unused wires to make the cable lighter. I checked the cable with an ohmmeter. Ground is closest to the plug base and the DJI video connection is the next ring up (the ring connected to the red plug). Other 3.5mm to RCA cables might also work and not need to be trimmed. However, I did notice that some of the other 3.5mm plugs were not all the same length. This one measures about 17mm while some other 3.5mm connectors, my headphones for example, are only about 14mm long. My setup also required an RCA female through to bridge the 2 RCA male connectors.
WindSwallow 5FT Gold Plated 3.5 mm to RCA AV Camcorder Video Cable,3.5mm Male to 3RCA Male Plug Stereo Audio Video AUX Cable for TV, TV Box, Home Theater / 3.5 Straight to 3 RCA
https://www.amazon.com/3-5mm-Audio-Video-Stereo-Theater/dp/B08BNC5FKW/ref=sr_1_1?keywords=WindSwallow+5FT+Gold+Plated+3.5+mm+to+RCA+AV+Camcorder+Video+Cable%2C3.5mm+Male+to+3RCA+Male+Plug+Stereo+Audio+Video+AUX+Cable+for+TV%2C+TV+Box%2C+Home+Theater+%2F+3.5+Straight+to+3+RCA&qid=1637623766&qsid=136-4632249-2256149&sr=8-1&sres=B08BNC5FKW%2CB08V1SV8BL%2CB096DVP5Z6%2CB07ZKPJMYN%2CB092VVR7M8%2CB092VKJVJN%2CB0957DDZK9%2CB08GK689GH%2CB098NSKK75%2CB08GFHKVB3%2CB095BT3J6Z%2CB079DDX1N9%2CB08BNL7K9R%2CB06XKMBB9L%2CB07D8M5DML%2CB08F3F9F66&srpt=ELECTRONIC_CABLE
RCA Female to Female coupler
https://smile.amazon.com/dp/B071FB7D4C?psc=1&ref=ppx_yo2_dt_b_product_details
